My 1st bricknose, e4od question
Old Yesterday | 10:42 AM
rword's Avatar
rword
Just drove this 8hrs home from Seattle ! One question I have is about the e4od overdrive off switch… did every truck come with that switch? Mine is missing and I don’t even see the wiring for it inside the dash area.
Old Yesterday | 10:47 AM
rla2005's Avatar
rla2005
If the truck actually has an E4OD transmission there will a switch on the dash to disable 4th gear.
Why do you think this truck has an E4OD?
What is the Trans code on driver side b-pillar?
Old Yesterday | 10:49 AM
rword's Avatar
rword
trans code E
Old Yesterday | 12:15 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Did you seem to have an overdrive trans? After driving 1 minute, let alone 8 hrs, you'd know haha. The trans pan dont lie. Get a look under the truck and look at the trans pan. E4OD says "metric" right on it. If it only shifted 2 times and you didn't feel a converter lock, someone swapped in a C6.
Old Yesterday | 12:58 PM
rword's Avatar
rword
I found the switch ! It broke off and was sitting behind the trim piece. Rigged it back in place
Old Yesterday | 01:29 PM
tjc transport's Avatar
tjc transport
i ain't rite
that aint no riggin, that is a purrfeshional fix. riggin it would be using crazy glue and bailing wire!!
Old Yesterday | 02:19 PM
rword's Avatar
rword
thanks ! Do you happen to know what the red light is that sits to the right of the overdrive switch ?
Old Yesterday | 05:33 PM
tjc transport
i ain't rite
got a picture? i have had C-6 in all my trucks, so do not know where the OD switch would be.
RRE101
Jun 14, 2010 07:57 PM
CT
Jul 9, 2005 05:02 PM
