7.3 Godzilla Alternators and lithium dc/dc charging...
Old Jun 5, 2026 | 08:50 AM
buzzzmea's Avatar
buzzzmea
Hey Team Zilla...
I have a 2022 F350 Zilla that carries a 6000lb Host Cascade Truck Camper. I optioned the 397 Amp alternator / dual batteries. After some researching, the "secondary alternator" is a 157 amp alternator. I am going to be installing a Bluetti RV5 all in one lithium battery system into my camper. It has a dual 12vdc auxiliary where one leg can be used for solar charging and the other input for the DC/DC charging (or both can be from the alternator or generator). So my main question is this: Is there a direct swap out High Output alternator that is 250-300 amp that I can just swap the factory "secondary" 157 amp alternator out with? I am adding the max battery system I can fit in the camper...probably 3 of the Bluetti system 51.2volt 100 amp hour batteries and I want the max alternator charging I can fit under the hood....or...if anyone has a similar set up or uses the Victron setup..is that 397 total amp factory option sufficient for what you are doing or needing? I am looking for only the Godzilla / dc/dc lithium charging angles...so any type of RV or "other" lithium charging via the alternator experience is awesome....
Old Jun 5, 2026 | 11:47 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I don't have this answer, but someone who does will probably want to know:
- How much of your 300ah are you expecting to charge with the engine alternators? Like 40% or 10% or 100% or . . . ?
- How fast do you want to charge them? . . . as in "during a 1-hour drive? . . . or an 8-hour drive? . . . etc . . . ?
- How fast can they be charged safely?
Old Yesterday | 03:06 PM
ejkTN's Avatar
ejkTN
Can't answer your questions but please watch this video as it may save you from damaging or destroying your alternator if the BMS suddenly cuts current:
. I don't know if the Bluetti RV5 has any protection scheme for this scenario.
Old Today | 06:58 AM
buzzzmea's Avatar
buzzzmea
The RV5 has two onboard dc/dc charging inputs...So I would think that they have some "protection" from a catastrophic loss of battery voltage feeding back into the alternator "systems"..... But I dont know for sure.
buzzzmea
7.3L / 6.8L V8 Gasoline Engines
Jun 8, 2026 08:11 PM
personanongrada
Apr 29, 2022 11:50 AM
pack4tag
Mar 30, 2017 03:00 AM
brandon.edwards
Mar 14, 2013 09:23 AM
klw033
Jul 31, 2009 07:07 PM
