Sponsored by: Real Truck
Charging system question
Old Jul 30, 2009 | 09:05 PM
klw033's Avatar
klw033
I'm looking for the alternator output specs for a 1999 F-250 Super Duty with the 6.8L engine. I'm pulling a 12,000# fifth wheel camper and am wondering what the OEM amp output of the alternator is supposed to be, what is the best way to test the alternators present capability,
and what is the best way to check the amp draw. I have a clamp type amp meter that can measure DC amps if that helps.
Thanks
Old Jul 31, 2009 | 06:57 AM
12ozd's Avatar
12ozd
The alternator amp output should be stamped on the alternator.
( I would assume there was more than one alt.option)
A DC amp clamp would work fine.
Old Jul 31, 2009 | 07:17 AM
QwkTrip's Avatar
QwkTrip
The process that most OEM's use is to make sure the alternator charges the batteries 99% of the time. This basically means all the time with the exception of intermittent loads such as windows, seats, etc...
You are interested to measure the difference between alternator output current and all current going in/out of batteries. As long as the alternator can cover electrical loads at idle with the trailer hooked up, lights on, A/C blasting, and any other accessories you use for long periods then the alternator is sized properly. Alternator output will improve when the engine speeds up so you will charge batteries well when driving. SAE specifications recommend 10A charging capacity per parallel set of batteries.
Old Jul 31, 2009 | 06:00 PM
klw033's Avatar
klw033
Thanks very much for your replies. This site has ended days of asking those who should know. I can't thank you all enough. I'm sold on this forum.
Thanks again
Keith
Old Jul 31, 2009 | 07:07 PM
ReAX's Avatar
ReAX
Here's what I've learned about them. OE's give you about 10% headspace, meaning if the stock alt can produce 130amps, the truck needs ~117A with most of the accessories running. This gives you ~13A to recharge the battery under the worst conditions (lights, heaters, AC compressor, wipers, ect running.) It also means if you go much over 13A, you run a good chance of not charging or draining the battery if you have all of those accessories on and additional (aftermarket) 13A loads.
The OE spec's I found were 130A, but all of the remans I could put my hands on at the time were only 110A. For measuring output, you have two options, you can use your inductive clamp or put in a shunt on the charge wire and watch the voltage drop across it. Shunts for 150A are expensive to buy, and probably dangerous (to your alt and possibly yourself) to home build if you don't know what your doing.
Also, Welcome.
