1979 F150 Aftermarket Seatbelt that turns off the fasten Seatbelt Alarm and light
Is there an aftermarket seatbelt that will turn off the fasten seatbelt light and buzzer? Or is there a work around, other than disabling the light and buzzer?
Wiring to the dvr side buckle come from under the dash over by the dimmer switch and goes under the vinyl / carpet (on the dvrs side) right across the middle of the floor pan.
Legend Accessory Power Feed........B. Seat Belt Warning System.
Generally
Either that or jump the wires
In '74, the car wouldn't start until the belt was buckled
That lasted about 5 minutes before mechanics started jumpering the seatbelt latch under the drivers seat
