Looking for headers, that will work with 4x4,
Old May 31, 2026 | 01:50 PM
PaulCf250,5.8,89's Avatar
PaulCf250,5.8,89
4wd Low
Hi guys, I currently have my 351 Windsor on an engine stand and I'm doing a gasket overhaul and seals as well as some other things. I am considering putting a pair of headers on the truck, I have a 1989 Ford f250 4x4, 351 Windsor with a C6 , and a Dana 50 ttb in the front,
I'm not looking to break the bank on these, I believe I need shorty headers, if anybody has ran headers on these trucks before, any advice would be appreciated. Thanks in advance.
Old May 31, 2026 | 07:34 PM
whisler's Avatar
whisler
I have almost the identical truck and setup and used JBA shorties. Happy with mine.
Old May 31, 2026 | 07:43 PM
90project5.0's Avatar
90project5.0
I use Hedman shorties. Only time you need “specific” headers would be long tubes. Shorties will bolt straight up to Y pipe.
As long as they are for a 351, they will work. Delete the EGR tube and you can use 302 headers.
Old Jun 1, 2026 | 09:29 AM
PaulCf250,5.8,89
4wd Low
Thanks
Thanks guys, I will look into it.
Old Today | 11:45 AM
torq'ta 5 8's Avatar
torq'ta 5 8
My BBK's haven't leaked since install 5-7yrs, put the stage 8 locks on them, and your done
Old Today | 11:59 AM
90project5.0
Might I suggest header gaskets, I kept getting leaks until I bought a set of remflex gaskets. Solved that problem!
Old Today | 04:33 PM
cougrrcj's Avatar
cougrrcj
My buddy did the same (JBA shorties) with his now-393W '95 F250XL/standard cab, 8' bed 5.8L auto 4x4.
Old Today | 05:12 PM
cougrrcj's Avatar
cougrrcj
302 headers are NOT the same as 5.8L headers. The factory Y-pipe WILL fit 5.8L shorties, but 5.0 shortie exits will be too far apart and an inch higher, making pipe from there back more difficult fitting around shift linkage, 4x4 driveshaft on the drivers side, and may hit the AC plenum on the passenger side. The 5.8 shorties are routed tighter to the engine block and extend farther down.
Old Today | 05:29 PM
90project5.0
My mistake! I could have swore I read threads on people using them if they deleted the EGR. If they are longer, then in theory 302s could use a 351 y pipe with a little finagling.
Tim J Miller
Feb 15, 2012 10:07 PM
Poulsom
May 22, 2005 03:32 PM
Phessor
Jun 23, 2004 10:51 PM
77' f-100 ranger xlt
Dec 8, 2003 12:40 AM
BlueTorpedo85
Exhaust Systems
Jan 29, 2003 10:47 AM
