1968 FE360 Thermostat Bypass
Old May 30, 2026 | 06:06 PM
Jim-68-BMPSDE's Avatar
Jim-68-BMPSDE
3rd Gear
Good evening fellow Enthusiasts! I've acquired a 1968 Ford F100 with the FE360 engine. I am trying to understand about the thermostat bypass. I can't for the life of me see an Internal bypass that a thermostat will block. I do see a short "bypass" hose from the top center of the water pump, to the intake directly beside the thermostat opening. Is this my bypass? I'm Trying to determine if i need a special "Hat Type" thermostat to close off for bypass, but again I just don't see it.
Old May 30, 2026 | 09:49 PM
blue68f100's Avatar
blue68f100
Yes, the short hose is the by-pass.
Old May 31, 2026 | 02:01 AM
1TonBasecamp's Avatar
1TonBasecamp
I thought the special type of thermostats were for the 351 Cleveland (USA type) engines only? Did some FE's use the same (or similar) style?
Paul
Old May 31, 2026 | 06:56 AM
blue68f100's Avatar
blue68f100
The Cleveland's had a special spacer/washer that went in with the thermostat to do the by-pass. I don't recall any FE's using it. The short by-pass hose can be a pita to change. If I recall there is only about 1" clearance between the 2 pipes to work the hose in.
Old May 31, 2026 | 10:12 AM
Jim-68-BMPSDE
3rd Gear
Thanks, so no special "Hat" type of thermostat... Just correct size and appropriate temp. Thinking of going with a 180 degree. The old thermostat measured 2.12 inches. Fit really sloppy in the "recess" of the housing. That recess measures about 2.3 inches
lshort
Sep 7, 2024 01:40 PM
bismic
Aug 9, 2014 06:30 PM
fuzzy1626
May 2, 2008 02:28 PM
freejay
Oct 10, 2007 06:38 AM
t.j.g.
Jan 18, 2005 08:46 PM
