dipstick tube in timing cover
Old May 23, 2026 | 02:27 PM
G_73SCS's Avatar
G_73SCS
Hi!
as far as I know I've seen every dipstick tread, but no cigar..
I have a 73 F350 460 and replaced the timing cover. (where the dipstick goes in as well) It's an aftermarker one and I bought a new dipstick tube as well.. (same as OEM I assume)
Now the problem is that the tube doesn't go in the timing cover far enough.. I heard it should stick out on the upper side only 13/16 " but it's sticking out about 2"
should i try to tap it in further with force? (almost sure it's bottoming out) or just cut it to the right sitting height?
And if I just put a bit of RTV on the lower hole, will it seal enough?
Thanks for any help in advance!
Old Today | 02:12 AM
Renwaldo's Avatar
Renwaldo
6th Gear
If either the timing cover or the dipstick tube is Chinese, any problem is very possible.Try another dipstick tube. Sealing with RTV has always worked for me.
DisneysPatB
Feb 1, 2021 09:21 PM
MikePacey
Jan 19, 2012 04:38 PM
C.Thompson
Dec 17, 2009 04:14 PM
nkapphahn
Apr 15, 2009 07:57 PM
ZRX61
Dec 26, 2002 07:27 PM
