Ford 289 Block With Factory Repair
Old May 20, 2026 | 03:25 PM
DaveMcLain's Avatar
DaveMcLain
It is amazing sometimes how much trouble they went through at the factory to repair a block with a casting flaw. This 1965 289 was completely original when it came in the shop and check out what one of the main saddles looks like after hot tanking. It looks like they welded it up and sent it down the line.
Old May 21, 2026 | 08:31 AM
1Butcher's Avatar
1Butcher
F-it, it's not my car.
I know a good welder can save you a ton of money, but I would not use that block. Not saying you can't, I just would not. Just like a totaled car, I would never own one.
Old May 21, 2026 | 08:59 AM
DaveMcLain's Avatar
DaveMcLain
The block is out of a '65 Fairlane and it has been doing fine for all those years it still had bearings with 3-65 date codes. From what I can tell at the factory they must have spray welded that area before machining. I've seen that other times on cylinder heads, China walls, pan rails but probably not a main saddle.
Old May 21, 2026 | 09:02 AM
1Butcher's Avatar
1Butcher
The proof is in the pudding, but I still would not use it. I can't argue that it's going to break. I would be an idiot if I did. I was 4 when that block was made, you can't argue that it won't work. One thing for certain, you can't say it won't work.
It's just not for me.
Old May 21, 2026 | 09:09 AM
DaveMcLain's Avatar
DaveMcLain
Also it is just a stock 289 engine that's not being used for racing or any real performance. It is just amazing to me that the factory went through that much trouble to save the block. I had an AMC 360 block out of a Jeep one time where you could see where the main line bore had been corrected. It looked like the boring tool had some kind of a problem and dug in. I could see where the caps had been trimmed and the block had been line honed. All factory.
Old May 21, 2026 | 09:48 AM
rwfid's Avatar
rwfid
There are a lot of tricks to getting a good weld that will be stronger that the base metal. Each metal type has different processes that you need to go through to achieve that, including a good cleaning, the correct welding process, proper filler metal, proper preheat and post heat, a well trained welder..... When I was in the military, a couple of airmen came into our shop and asked one of our buck sergeants if we could weld up a 426 Hemi block that they had found in the junk yard. One of the cylinders had been split clear up the side. We just laughed at them, not only because it would have been a court martial offense for us to do so, but because we felt it would be foolish to trust a block that had been repaired in that location. I still wouldn't trust a weld repair in that location for any motor, but with the right equipment, a weld repair on cast iron should hold up well.
Old May 21, 2026 | 09:51 AM
1Butcher's Avatar
1Butcher
Without a doubt, there are skilled craftsmen that AI can't compete with [yet]. No one has accused me of that. Hence the name Butcher.
Old May 21, 2026 | 09:59 AM
rwfid's Avatar
rwfid
I've seen a little of your TIG welding. You do pretty well for someone who hasn't been formally trained in welding. The fact that you know to purge your welds and keep your color when welding shows that you aren't the Butcher that you think you are.
Old May 21, 2026 | 10:06 AM
1Butcher's Avatar
1Butcher
I'm progressing on my headers and you should see the welds now. As I mentioned before, I am a better grinder than welder. I'll update my header thread someday.
My welds might look good because of the diffusion filter on my camera.
Old May 22, 2026 | 08:11 AM
wwhite's Avatar
wwhite
When I did my exhaust, my son told me: "A little grind, A little paint, A welder you ain't"
Old May 25, 2026 | 10:33 PM
SDDL-UP's Avatar
SDDL-UP
Hmmm..... I'm skeptical that's a weld repair. Not sure what it is other than unusual.
I just imagine piles of "problem" castings being remelted and re-cast.
Old May 26, 2026 | 08:50 AM
1Butcher's Avatar
1Butcher
I would agree with you but I've seen enough welding repairs and when you machine the area welded, it looks exactly like that. I too would think they would just send it back to be melted again, but working at the dealership for 30+ years, the factory never asked me my opinion.
Old Yesterday | 01:45 PM
DaveMcLain's Avatar
DaveMcLain
I assume that even though Ford was casting 289 blocks by the thousands they still had a fair amount invested in each casting so it was worth it to have some people at the factory to fix that sort of thing. I wonder when the flaw was discovered? Right away or partially though production machining?
Old Today | 09:21 AM
1Butcher's Avatar
1Butcher
Nobody knows, but I bet it was with the first inspection. They did not have computers and robots back then so I bet there were plenty of people looking for problems.
814x4390
May 16, 2024 11:41 PM
dnpowers
Apr 30, 2023 08:08 AM
TMI
Jan 8, 2014 12:04 PM
