Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1985 Ford F700 Dump truck
Old May 15, 2026 | 07:28 PM
mnewcomb's Avatar
mnewcomb
6th Gear
Neighbor said I can have it if I can get it running. Been sitting for at least 4 years. Reconditioned the batteries, trimmed some degraded battery cables, started right up. It had sunk a little into the dirt (in Florida). Dug it out, but can’t get it out.
Seems that the back right wheels are seized or something? The back left spins when I put it in gear (forward and reverse), but the back right is just locked.
As far as I can tell, no brakes are on (service or emergency). The only thing I can think is that the pads are rusted/stuck to the drum?
I peeked under and snapped a few pics and it looks like someone tried to cage the brakes? That bolt is backed out.
I read that you can somehow see if the pads are up against the drum?
Anyway, I’ve attached a few pics.
Old May 18, 2026 | 10:41 PM
The Extractor's Avatar
The Extractor
Those are the Lucas Girling brakes. They are all hydraulic. They are a crappy, complex alternative to air brakes. They look caged and can be caged just like air brakes. There should be a small rubber plug somewhere in the sheet metal on the backing plate for shoe to drum clearance / inspection. Or cut and bend it if you don't care. One of my trucks had a stuck brake but it is not that style. I adjusted it and pried on it and it finally let go without a ton of hassle.
Old Today | 03:42 PM
mnewcomb's Avatar
mnewcomb
6th Gear
I think I saw the rubber plug. Was there 2?. Was planning on trying to spray a whole can of pb blaster in there and seeing if it will let go. Otherwise I need to pull the wheels off and open it up... was hoping I wouldn't have to do that.
Old Today | 04:03 PM
The Extractor
Yes I think there are 2-3 plugs. I would not spray oil in there as you will have to clean it later. I would try to adjust the brakes in then pry on the shoes and tap the drums if you can to save all the labor of taking it all apart annd cleaning it unless you were planning on doing that anyway.
Old Today | 04:08 PM
mnewcomb's Avatar
mnewcomb
6th Gear
My main goal is to get it out of his field and into my big garage in the next field over. I have a brother and brother-in-law with ex-Army mechanics and a bunch of nephews that I can turn loose on it and plan on taking them apart anyway. It was sitting for at least 4 years since I bought the property and we had a hurricane here and there was probably 6" or so of water in these fields for a day or so.
You think if I go to town with a hammer on the back side it might brake them free? Or do I need to at least remove the wheels and bang on the drum without the wheels on?
It has other problems... like the gas pedal floor mount has rusted off so I have to reach down and grab it to rev it This baby needs a lot of attention to make it road worthy.
Old Today | 04:23 PM
The Extractor
Hmmm being submerged in salt water makes me think it will be very stuck. Be careful not to destroy the drums as some are not available new or hard to find used.
Old Today | 04:29 PM
mnewcomb's Avatar
mnewcomb
6th Gear
I won't go too crazy, but what do you think are my chances with tapping the drum from the back side?
Old Today | 04:46 PM
mnewcomb's Avatar
mnewcomb
6th Gear
Sorry, we are inland in Florida, so it was just rainwater, not saltwater. Sorry if I implied that.
Old Today | 06:58 PM
The Extractor
Oh , no problem, I assumed. If you do give it some hammer time I would hit the outside diameter of the drum if access allows maybe with a steel bar or heavy oak board to shock the shoes loose, 90 degrees to your arrows. The part you suggested is just sheet metal and will deform. I’ve never messed with Dayton rims. If you have a way to do it jack it up and remove the inner wheel and then hammer the drum.
Old Today | 07:56 PM
mnewcomb's Avatar
mnewcomb
6th Gear
Yeah, I saw that is just some sort of guard. I think I’m just going to have to pull the wheels off. Was hoping I didn’t have to do that, but looks that I will have to. Thanks!
GB SISSON
Mar 23, 2025 05:01 PM
idealtrucks
Jul 17, 2023 10:03 AM
WA.Ranger
46
Feb 14, 2011 10:49 PM
qwertmonkey
Dec 3, 2010 02:38 PM
Fordzilla80
17
Jun 6, 2009 05:03 PM
