6R80 Cooling lines
Old May 9, 2026 | 03:43 PM
TonyFio's Avatar
TonyFio
4wd Low
6R80 Cooling lines
Brian at FordTechMakuloco recommends changing out the cooling lines before they fail. I'm right about 90K miles on my '09.
I'm wondering if this is more of an issue where freezing and road salt are contributing or not. I live in S California far from the ocean. It's typically dry, no freezing and the truck is always garaged.
I saw some comments that the issue could be arising due to dissimilar metals in contact (aluminum and steel).
So, do I change out the lines preemptively? Also, what approach should be taken for future replacement (miles, years in service)?
Old May 9, 2026 | 05:14 PM
2jhanna's Avatar
2jhanna
Here’s one of many threads on the subject, from another forum, I’ve done mine.
https://www.f150forum.com/f38/bullet...r-line-524747/
Old May 9, 2026 | 07:32 PM
TonyFio's Avatar
TonyFio
4wd Low
Thanks for this reference. That thread is currently active. There isn't any info on whether this problem is weather related, but it does provide a good path for a long term repair.
I think I will go with the approach of removing the crimp connectors and double clamping with high quality clamps such as Norma, running the hose directly up to the cooler. I don't like the idea of leaving the crimps and inserting barb connectors. I've seen those fail too often in other non-critical applications.A failure in my wife's backyard fountain just gets gripes from her. It's not like the risk of losing a several thousand $ trans.
Old May 9, 2026 | 07:54 PM
2jhanna's Avatar
2jhanna
Here’s one more related thread, plus even more threads in post 7 of the link below,
https://www.f150forum.com/f38/friend...-lines-584645/
Old May 10, 2026 | 01:18 AM
TonyFio's Avatar
TonyFio
4wd Low
That's interesting about the vehicle that spent its time in Arizona. Probably drier there than where I live. Also, coincidentally, I contacted my nephew who works in the parts dept at a Ford dealer in central Ca. He checked with service guys there who also said they haven't seen this problem. Makes me wonder if the dealers don't want to admit it?
In any case, it looks like an easy enough fix with the rubber hose.
Old May 11, 2026 | 07:51 AM
explorerdriver's Avatar
explorerdriver
This generation is 12 years old and a problem like that is less likely to go back to the dealer. The parts guy can check sales of a particular part, possibly for a region or nationally.
It is not going to happen to every truck. However, if it fails in 2-3% of trucks - that becomes a serious problem. There are actually two failure routes. The crimped shells can also split.My truck has traditional power steering. The line was replaced in the past per the records, and I see it seeping around the crimp, so I would probably look at another brand of hose. Seems the same company made both hoses.
The problem isn't always rust related, the pot metal can get fractures and fail. I would not buy the factory part because there is no improvement. Time goes by fast, you don't want to worry about this 8-10years from now.
Old May 11, 2026 | 01:38 PM
TonyFio's Avatar
TonyFio
4wd Low
Good points. Thanks.
I'm to the point of looking at which cooler hose to buy. I can get Derale or other performance hose that looks to have higher pressure and temperature specs than the generic Napa, etc. hose.
I also talked to my local hydraulics hose/adapters place about putting some type of compression adapter with a barb on the end of the steel line rather than just clamping the hose onto the line. Trade off of the barb will provide a more secure attachment for the hose, but it adds the failure point of the compression fitting.
Old May 11, 2026 | 02:40 PM
explorerdriver
NAPA 400PSI lines are plenty. I think they are made by gates. The hose has 3 serrations (not a barb, which is for the crimped shell). Clamps bite into these.
You can also try to slide the tube over the bead, possibly file down the bead on the tubing a bit if it is too tight. 2 clamps on each side - even without serrations that would be something on a factory hose connection.
Old May 11, 2026 | 02:51 PM
2jhanna's Avatar
2jhanna
in my opinion, you’re wayyy overthinking it. Guys have been adding trans coolers to vehicles for many, many years, using standard hose and clamps. Even the black rubber hose Ford used between the metal lines is standard stuff.
NAPA or Gates trans hose and some stainless clamps, an hour in your driveway with a dremel tool is all you need.
Old May 11, 2026 | 04:06 PM
TonyFio's Avatar
TonyFio
4wd Low
Ok, thanks for the feedback guys. Napa hose it is!
Old Yesterday | 12:53 PM
HomerWinzlow's Avatar
HomerWinzlow
Its not the crimp connections that you have to sweat, its the quick couplers snapping off. Of course the crimps need to be replaced as needed but the problem most suffered is snapped off quick couplers.
Old Yesterday | 10:31 PM
wirelessengineer's Avatar
wirelessengineer
I bought my 2011 last year in Paso Robles. Right on the coast. When I learned about this I carefully inspected the lines. I see zero signs of corrosion.
But now the truck lives in Virginia, and I may go ahead and do a preventive repair. In the interim, they got a good shot of Fluid Film.
Old Yesterday | 10:33 PM
wirelessengineer
Agreed. Transmission cooler lines are NOT high pressure lines. I remember reading something like single digit PSI.
Old Today | 07:06 AM
explorerdriver
I don't know about a few PSI. The pump can produce a few hundred PSI to lock clutches. By the time it circulates the pressure is much less but the NAPA ones are 400PSI rated. 50 would be max for those lines.
Old Today | 08:09 PM
wirelessengineer
The pump pressure is not relevant to the coolant lines. Your 50 is closer than my single digit, but it's still well within hose barb and clamp range.
Originally Posted by Mark Kovalsky
That's not accurate. The pressure in the trans cooler lines varies quite a bit due to trans type, temperature, engine speed, etc, but it can be around 30 PSI. That's about twice the pressure in the radiator.
https://www.ford-trucks.com/forums/1...l#post18967782
