6R80 Cooling lines
https://www.ford-trucks.com/forums/1...l#post18967782
Pressure has to do with volume and restrictions. The orifice tip of your pressure washer actually creates the pressure. Take the nozzle off a pressure washer, and it becomes a garden hose. Put the nozzle on and the pump can force that same volume thru the tiny hole. Not so much for the garden hose. I have an adapter for pressure washer tips and it creates a nice strong mister, at 80PSI or so.
Lets say those lines move huge volume. 13 quarts can be gone in notime. The cooler creates some restriction as well as the tubing. So 30-50 sounds very fair. But yes, almost any line that says "Transmission" would be in that factor of safety. The 400psi rating on mine is probably way overkill, but maybe some racing or towing applications have elaborate cooling that creates lots of backpressure.
The whole idea of cooling is to circulate it quickly.
However the cooler lines are circulating enough fluid that a severly leaking line will drain the trans to sever damaging levels in in virtually seconds. That is why its so important.
Say your towing that 10k camper that should never be behind a f150 your in 4th gear doing 80 foot through the floor board. transmission and coyote are going for all there worth.
then suddenly the tach quivers steadies you think you imagined wait you were texting didnt even notice 30 seconds go by and the tach screams losing speed you pull over camper coverd in 16 quarts of transmission fluid.
Wife looking at you pissed 3 kids screaming in the back seat. Looking at a 7000-10k repair bill plus.
you could repair it cheaper. Though now is the time to upgrade in preparation for twin turbos
From what I've seen on the Valve body there is a thermostat and an orifice that may divert 10% of the fluid and reduce (but not eliminate) pressure. That large amount of volume creates that 30psi ish of pressure. NOT the 300PSI to move clutches.To get the 300PSI the fluid would pass thru very tiny orifices,and the pump is up for it. But technically the NAPA lines could handle it.
Trans is kinda my area up grading. Been thi king about a finned pan for mine along with being able to monitor temp. Not that it needs it, thats just what i do.
When i did lead frame i was impressed that the frictiins looked as good as they do. Though i dream of gpz frictions lol
Getting sidetracked with thus badass transmission
