91 F250 460 EFI stock 5,000' alt base timing 10 or 14?
Old Apr 27, 2026 | 02:36 PM
elkski1's Avatar
elkski1
when the rain stops and I get some time I am wanting to check my timing. I did install a new roller chain recently at 125k. Sadly the new chain had more movement than the old one. 3/8" vs 1/4"
So just to verify I remove the sprout and set the timing on a warm engine. I tend to buy the 91 octane as I have had some pinging in the past with the 87, I see 10 degrees everywhere but also 14 for altitude... Do I need to check the timing at other RPMS and adjust anything else... Idle is real good and she starts fine
Old Apr 27, 2026 | 03:03 PM
90project5.0's Avatar
90project5.0
I don’t know about the altitude, hopefully someone will chime for that. As for timing, moving rpm’s won’t change anything. When you remove the spout connector, there will be no advance at all.
Old Apr 27, 2026 | 04:53 PM
wwhite's Avatar
wwhite
If everything mechanical is in proper working condition, and every sensor is in proper working condition there is zero reason to change the base timing of 10* as that is what the EEC-IV expects is 10*, nothing else.
Since you already mentioned you have a slack in the timing chain, you already have a mechanical issue that may be causing the EEC-IV to behave inconsistently. You can't tune out or adjust timing to fix the mechanical issues.
The system has sensors to auto adjust and compensate for altitude. The MAP sensor was calibrated at sea level, and will give the EEC-IV information to adjust air/fuel mixture when adding altitude.
If it idles great, then I wouldn't change anything.
Old Apr 27, 2026 | 05:19 PM
Mudsport96's Avatar
Mudsport96
If you have ping at 5000 feet on 87 you have other issues. You need to check actual TDC with a positive stop tool and find true TDC on your balancer. To make sure the timing is accurate to the piston location not the balancer location.
You lose about 3.5 percent by volume O2 per 1.000 feet. So at 5,000 that is like what 16 or 17% compared to sea level. Rich mix alone should help stifle detonation unless the timing is way off. That is why 85 octane is available in the mountains, because it lights off easier.
Always check codes too. As they don't always trip the CEL.
Old Apr 27, 2026 | 06:21 PM
elkski1's Avatar
elkski1
I was disappointed with that new timing chain assy. I really thought about going to get a different one. looking back now I may really regret that considering how easy it is to change when its all opened up. The occasional ping which has not been an issue for 2 years since I started buying 91 and it was only when its real hot and under a load. of course at 4.20$ a gal for 87 and 10 MPG I may be wanting to try the 87 gas again.
Old Apr 27, 2026 | 06:27 PM
90project5.0
You could always do mid-grade. Do like mentioned and double check timing to be at 10*. What was the condition of your harmonic balancer (the middle seal)?
Old Apr 28, 2026 | 10:45 AM
1Butcher's Avatar
1Butcher
That is true, but normally the entire ignition map is based on using regular gas. If the OP uses premium, then advancing the timing might help. Using premium with the ignition timing set to regular gas is a waste of money.
The way I see it, it's not hard to just adjust it and see what works for you. Asking this question is just going to get a lot of opinions based on experiences from all over the world. Denver is different than Seattle [except for the politics]. Every one is not right or wrong.
Old Apr 28, 2026 | 12:24 PM
elkski1's Avatar
elkski1
I got a new timing light and it has this changing angle feature. I Pulled the sprout after I found it down low on the fender near the firewall. The light started at 10 degrees? I guess that was the default and what I want ? the mark on the harmonic is running on the drivers side of the indicator about an inch... when I change the timing light advance number to 0 the mark is right on the indicator. My RPM is 700
So to me this means the timing is currently set to 0 advance. I read you need to rotate the distributer CW to advance until the mark is on the indicator when my timing light is adjusted to 10. I got it set lined up at 10 on the timing light seemed to work fine for a few minutes and tries but the new light seems to have died it has intermittent flashing..Let me know if this sounds correct. I locked it in and will test drive it.
If I was set at zero timing would that explain pinging or running hot? I have since read that zero would make it run real hot at idle.. this may have been the big part of my cooling idiosyncrasy's
Old Apr 28, 2026 | 01:36 PM
seijirou's Avatar
seijirou
Originally Posted by elkski1
I got a new timing light and it has this changing angle feature. I Pulled the sprout after I found it down low on the fender near the firewall. The light started at 10 degrees? I guess that was the default and what I want ? the mark on the harmonic is running on the drivers side of the indicator about an inch... when I change the timing light advance number to 0 the mark is right on the indicator. My RPM is 720
Can't answer that unless you tell us what degree on the balancer the mark is at.
Old Apr 28, 2026 | 01:45 PM
wwhite's Avatar
wwhite
What timing light, make/model?
Normally to read straight up, set the dial to 0, chalk mark on your balancer at 10*, Spark Output(SPOUT) unplugged, start the engine light strobes at 10*, if off then adjust distributor.
So, if your mark on the balancer is at 10*, timing light at 0, your strobe light and mark is right under the indicator, PERFECT!! no adjustment needed, and your dist is timed correclty.
Turn off engine, plug SPOUT back in, continue with your day.
Old Apr 28, 2026 | 02:38 PM
elkski1's Avatar
elkski1
timing light is an amazon Autolumen store qz6803 digital with digital advanced timing.
I figured the groove in the harmonic that still has a white stripe is 0 degrees. when this is aligned with the timing light at zero advance it was lined up.to the indicator bracket.. Perhaps the guy I hired to do a tune up many years ago set it wrong or new timing chain changed it.
So now after I turned the distributor CW about 1/4- 3/8" with the timing light set at 10 advanced that white groove is right at the indicator. with sprout out...
Just checked the timing light on a different vehicle and it is not lighting on each fire.. its going back.
Old Apr 28, 2026 | 02:40 PM
90project5.0
Verify the white line on your HB has a “0” at it. There will be one on there. If you have the timing light advanced 10, then yes, the pointer should hit zero on the HB.
Old Apr 28, 2026 | 06:38 PM
elkski1's Avatar
elkski1
It seems to run fine. Not worse that is for sure.. not sure if better.
Old May 1, 2026 | 08:54 AM
elkski1's Avatar
elkski1
Seems to be running well. and I think it is cooler in the engine compartment. I did fill up with regular gas yesterday.
Latest issue is the drivers power window wouldn't' open one morning then later that day it worked and no not at all. Maybe wire in the hinge. I recall that before... I'm glad for wing windows.
Old Today | 07:27 PM
elkski1's Avatar
elkski1
replaced the drivers side window motor about 125$. all working fine now.
Now just The rear tank selects imediate running bad issue.
gsxr1jake
Mar 31, 2013 12:18 PM
Ken Blythen
Feb 3, 2008 01:06 PM
jadmt
Dec 31, 2007 12:21 AM
KSTTAC
Mar 31, 2007 07:02 PM
oricle
Jan 29, 2006 01:25 AM
