Sponsored by: Auxito
Correct tire size?
Old Mar 29, 2026 | 01:36 PM
syakoban's Avatar
syakoban
4wd High
Exclamation Correct tire size?
I've had my 2 door 8ft 2002 F150 2WD XLT for a couple of years and now it needs tires. It has 245/65/R17's on it now.
The factory tag shows 275/60/R17SL. Whenever I look up tires, I get:
The 275/60R17 tire size is an available OEM option for the Ford F-150 King Ranch and Lariat trims, specifically for model years 2001 through 2003 in Super Cab and Super Crew configurations.
What's the right tire for this truck? I use it on weekends to do side landscaping work and often drive on highways. I'm not going off-road, but drive in dirt, grass, rocks. A 60 series tire seems like a car street tire to me, not a truck tire.
Thanks guys!
Old Mar 29, 2026 | 01:50 PM
Pickupmanx2's Avatar
Pickupmanx2
Pick the tread pattern you like and go for it, maybe look for a nice AT, I have the Toyo AT3's on 3 of my other rigs and love them for all around everything, on my 2000 Scab F150/4x/7700 had 245/75/16 stock size on it, I use mine for an extra wood-cutter/hauler/wheeler/run-around truck, I wanted a more aggressive tire so I went with the Hercules TIS Mud Terrains in 265/75/16, Love them! They change the whole look/disposition of the truck.
Yes, I would go more towards a 265/75/17 in your case, you don't have to go with factory spec'd sizes, and size you load it like I do, I'd go for a Load Range E tire/size.
Before with 245's, after with 265's
Old Mar 29, 2026 | 02:48 PM
BareBonesXL's Avatar
BareBonesXL
Landscaping like hauling a mower and some rakes or landscaping like hauling a full bed of bark dust and/or gravel? You might want to study up on load ratings. And consider that the ride of a stiff sidewall tire can be rougher than a lower load rating tire.
And don't forget your speedometer reading if you get a different diameter. And road noise if you travel on the highway. Aggressive tread patterns can be noisy.
Pickupmanx2 used looks as a major choice factor. It's usually a compromise between looks and function. Overall, you can put whatever tire you want on your vehicle. None of them will damage the truck. It's how you use the truck and tires that matters. Good luck.
Old Mar 29, 2026 | 02:53 PM
syakoban's Avatar
syakoban
4wd High
Thanks guys. Looks are unimportant. I'm carrying equipment and a load of topsoil or mulch, so carrying capacity is most important. I don't want noisy highway tires, but that's secondary.
My old 1984 F150 4x4 had heavy duty leafs on the back and laughed at carrying 3,000lbs. This truck is much wimpier, so I've considered better springs, but might change the truck out if I really need them. But if I did put better springs, I want tires that can match up.
BTW - the speedometer is off with the 245s showing a little faster than comes up on radar, so I imagine it left the factory with taller tires.
Old Mar 30, 2026 | 06:48 AM
Hit Man X's Avatar
Hit Man X
265/65R17s on my Lobo, easier to find than the stock 275/60R17 for me. Size is close enough, I think it was about 0.5" different
Old Mar 30, 2026 | 09:27 AM
Pickupmanx2
Correction, I used function as my choice factor, the looks came after getting them on and really liking them, I wanted an aggressive MT for the intended use of the truck, if he was to be mostly a run-arounder I would've gone with the Toyo AT3's, but having been stuck cutting wood, I knew the AT3's, as great as they are would not be the best choice for the tasks asked of 456.
@ the OP, the Toyo and Falken AT's seem to be great all around tires, I have the Toyo's and they are quiet on the road yet have great traction in most everything with some limits expected from an AT.
Yes my MT's are noisy, personally, I've never cared about tire noise but that's me.
Definitely check load ratings, I've had some D's that were = to the E's, and IMHE, I prefer the stiffer sidewall handling, especially when I air down.
Old Mar 30, 2026 | 09:33 AM
Hit Man X's Avatar
Hit Man X
E codes weigh a bunch more, especially when in MT form...keep that in the back of your mind. I cannot see a reason for E codes on a half ton.
Old Mar 30, 2026 | 11:06 AM
Pickupmanx2
My 2000 F150 is the 7700, and it does get loaded... the worn out AT's were questionable, went to 4wd to avoid the possibility of losing forward momentum on the way out, this is why I went MT's in E
Old Mar 30, 2026 | 11:14 AM
Hit Man X's Avatar
Hit Man X
Are there no D rated for that GVWR?
You also have a truck no one really sees, most of these have a lame rating...like my Screw. Your average 10th gen has no need for E codes.
Old Yesterday | 06:22 AM
syakoban's Avatar
syakoban
4wd High
I was looking at these Kumho which have good ratings and are a good price: https://laughspark.com/product/kumho...17-121-r-tire/
Thoughts please. Thank you.
Old Yesterday | 07:08 AM
Hit Man X's Avatar
Hit Man X
Three peak snow flake is good, my Michelins have that on the Lobo. BFG also does with their Trailterrain on my Burb.
Owned some Kuhmo long ago on a car, seemed fine. Do you want the weight penalty of the E codes?
Old Yesterday | 10:15 AM
Pickupmanx2
I've never seen/heard of the laughspark website, however, I do know a few folks running Kuhmo's, no complaints that I've heard, I can't speak personally on them, but they seem to be good tires and appear that they would be a good all around choice, plus a nice price, but I'd be leery of the website... I've shopped for a lot of tires and never heard of that one.Never heard of it...
TrustPilot has no reviews and ScamAdvisor says it's legit, but looking at the details I don't think so. Known scammer domain, all contact info is free public addresses, low traffic overall...
https://www.scamadviser.com/check-we...laughspark.com
Google Maps street view says that their address listed on their website is an ice cream shop...
28 Haddon Ave, Haddon Township, NJ 08108
This would be a hard pass for me...
Old Yesterday | 09:21 PM
syakoban's Avatar
syakoban
4wd High
@Hit Man X thanks. Weight penalty? E code tires are significantly heavier meaning more rotating mass and worse fuel economy?
@Pickupmanx2 Thank you for checking their validity. I hadn't done that and don't need ice cream.
Old Yesterday | 09:51 PM
RacingJake's Avatar
RacingJake
I bought my F150 2002 in 2006 and it had taller tires and never knew it. I always replaced them with the same size tires for the past 20 years and always wonder why I was always passing cars doing the speed limit. My son got pulled over and the Cop said he was doing 95 in an 80 and he asked me if the truck had taller tires and I said I don't know let's check them lol.
Captainyamilo
Oct 20, 2024 11:36 PM
Kenny Bania
May 12, 2023 12:58 PM
Sarge261
Mar 8, 2012 06:57 PM
jeffl1980
Dec 9, 2005 01:59 PM
BlueMonster
Sep 18, 2004 11:02 PM
