Overweight on steer axle
Old Jun 29, 2024 | 09:46 AM
Awaldrup's Avatar
Awaldrup
Is this something you guys would be concerned about? The front axle weight is 300 lbs over max…I had myself and another guy when weighing (550 lbs) in the front seats and a rather large bumper and winch, 55 gallon fuel tank, but that’s pretty much it.
Old Jun 29, 2024 | 09:55 AM
chadstickpoindexter's Avatar
chadstickpoindexter
You could put some 5990 springs up front. Of course that won't change what your sticker says.
Old Jun 29, 2024 | 11:55 AM
SARDiverDan's Avatar
SARDiverDan
Weights on these trucks are all over the place and can change from year to year without changing any of the components. My stock truck is listed at 5600/7230 (12,830) but the GVWR is 11,500. I changed out the front coils for 5990s. According to the door sticker, I can carry 3,206 but my truck comes in at 9,100 pounds. Even though I added a front bumper and bed cover, they don’t account for the over 800 pounds from what Ford said it weighed before bumper and cover. Not to mention my registration shows an unladen weight of 7,336.
Old Jun 29, 2024 | 12:28 PM
nc350's Avatar
nc350
If exceeding your GAWR will increase your component wear or otherwise cause your truck to not perform as it's supposed to, I would be concerned.
That said, its just based on what I've read. I've not heard of accounts with overloaded (slightly) axles simply crumbling.
Old Jun 29, 2024 | 12:46 PM
Desert Don's Avatar
Desert Don
IIRC, front axle is the same, F250, F350 SRW, different springs…….unless FoMoCo has cheaped out again on something.
Old Jun 29, 2024 | 12:55 PM
senix's Avatar
senix
different spring is what determines the rating, with that said your axle is fine,
I always get the snow plow prep and then the springs are 6K. Helps with a heavy winch bumper.
Old Jun 29, 2024 | 03:17 PM
Joe T's Avatar
Joe T
You have 5600 and 5990 coils available.
Also aftermarket like Rough Country coils etc.
Old Jun 30, 2024 | 07:19 AM
B-ManFX4's Avatar
B-ManFX4
The OP didn't ask about what his springs are rated for - the question asked was is it safe to run with the axle weight 300 lbs. over what the sticker says? Does anyone have data on what DANA says that axle can safely carry? I tried finding it on their web site and everything I clicked took me to some stupid electric drivetrain pages.
The Wikipedia page I looked at says 6,500 lbs. for the rear axle version but it did not cite a reference or source. I found a rating chart on dieselhub.com that says up to 6,500 GAWR but again no citations or sources.
Old Jun 30, 2024 | 07:33 AM
Desert Don's Avatar
Desert Don
Since they use the same axle across all front ends in the 250 and 350 SRW, I would say he is quite safe. If he is going to worry about it he would need to remove all aftermarket accessories and move on from there.
Old Jun 30, 2024 | 08:04 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Or weight could be added to the rear of the truck, aft of the rear axle, which will unload the front axle.
The tongue weight of a trailer, for example, can unload the front axle by 300 lbs.
Old Jun 30, 2024 | 09:05 AM
speakerfritz's Avatar
speakerfritz
I would level it to see if some weight will shift to the rear.
Old Jun 30, 2024 | 10:03 AM
BadDogPSD's Avatar
BadDogPSD
This is what i would do.
Old Jun 30, 2024 | 02:23 PM
Joe T's Avatar
Joe T
The safety issue is that the springs in his truck won’t support the weight? He can go up to factory 5990 springs.
Does that answer your question?
Old Jun 30, 2024 | 04:52 PM
kayakingpoodle's Avatar
kayakingpoodle
But that may cause warranty issues, the 24 passenger side fixed hub rattle comes to mind.
Old Jun 30, 2024 | 09:08 PM
Awaldrup's Avatar
Awaldrup
I also failed to mention this has a Carli Eventure lift…lifts tremor models maybe an inch and a half. I have at least an inch and a half of rake…which I prefer. I’m having a difficult time finding the load capacity of the front springs. I’ll call them tomorrow.
