Poor fuel economy
Poor fuel economy
Hello, I have a 1985 f150 2wd with a 302 and a 4 speed overdrive rts manual, it has the c ratio for the gearing and 3.27s in the rear, I have a 2150 2bbl on the motor, it has been bored 30 over and a mild cam apparently, this is how I bought the truck, but it gets very poor mpg I daily it to work which is about 20ish miles one way, any advice would be useful, I was thinking about doing a 4bbl swap
Yes what are you getting now for MPG?
Also install a Air Fuel Ratio gauge as it will tell you if running rich or not.
Dave ----
on
7-9 mpg is extremely poor mileage indeed. The 2150 carb came in two types, feedback and non feedback types. Many people have reported poor mileage with the feedback carb. For comparison I ran a stock 350 GM engine in a 73 half ton pickup with a 2bbl Holley and consistent 18 to 20 mpg. No smog stuff, straight stock, dual exhaust.
I have a feeling that your issue involves the feedback carb that is no longer under control. Either that or a fuel leak. 15 mpg should be easily obtained with a 302.
Also....
a 4 speed overdrive rate manual, it has the c ratio for the gearing and 3.27s in the rear
Can't say I have ever heard of that.
If he has the AOD and somebody swapped the feedback carb, did he get one for the AOD and have the linkage adjusted properly?
Has he done the DS2 swap?
If not, and still running the stock dist., then it is probably in limp mode.
Also....
Something is going on here. 1985 should have a fuel injected engine. I wonder what distributor he is running. He said the engine was rebuilt but sounds like there has been lots of modifications. It would be interesting to find out what exact carb and what ignition system he is running.
I would suggest putting a timing light on it per the instruction label on the radiator support. See where it is set and if it advances. If it has TFI, ECM controlled ignition it may very well be stuck at base timing. That's easily a recipe for 7-9 mpg.
Proper spark advance might wake up the "mild" cam.
