96 F-250 460 crank, no start
Tach is bouncing around with the key on.
It's making a growling sound around the engine fuse block.
has fuel in both tanks. front is full, back is at 3/4. Premium fuel only.
All fuses are good.
160k on the odometer
It usually runs great. I set the cruise at 80 with no hick-ups. I drive it between 500 and 1000 miles a month.
up until this point its been rock solid dependable.
Any ideas?
All fuses are good.
Any ideas?
on
me too, anything electrical I check the grounds first. About once a year I go through, pull them loose, clean and bolt them back. I checked them (pulled them loose). Good contact and everything was tight.
eamay
03-28-2008 08:44 PM
frigerator
04-19-2007 12:27 AM
