TPMS Alert Issue
TPMS Alert Issue
Hello, I got a low tire alert (not sure why since the tire displayed was only 2PSI low and in the shade while all the rest had been sitting in the sun). Anyway. I followed the directions:
Key on Hazards pushed 3 times - horn honk and panel states to proceed.
Aired down each tire until the horn horn honked for each and panel said programing complete.
I then filled the tires back up to the 56PSI I run when empty expecting the issue to be resolved - Wrong.
Now when I start it I get the alert that the 2 rear tires are low and the symbol on the dash is illuminated..
Anyone have issues with not being able to reset the sensors? I might give it another try in the morning when it's cool outside. If it does not work a second time I may go talk to my buddy at discount tire. I'd hate to run it through the stealership for something so minor.
Uh you might want to watch your spell check pal.
The following 2 users liked this post by Just Chilling:
I just did this on my 23 last month after a tire rotation and had no issues. Did you drive it over 20mph for at least 2 min before you started the reset procedure? As djousma mentioned, if you can’t change the values in FORSCAN, then you might have to run your rears over 60.
The one time I had a tire trigger the TPMS alert, it took me filling to recommended PSI for the light to go out. No relearn procedure, just drive it.
Kidding aside, I run 56-58 F, 60-62 R cold. I also lowered the warning threshold with FORSCAN.
I know you do not have it, maybe someone local does and can adjust it for you.
Where are you located?
And just for the record, "retraining" procedure is only for telling the truck what sensor is at what location. does nothing to retrain tire pressures. Also Forescan is free, just have to buy a bluetooth or wired OBD adapter to do the changes. that was the first change I made to my new truck, lowering the PSI to 60 all the way around so that the warnings dont come on when I air down to 60 all the way around.
What is the pressure shown on the jamb sticker? You shouldn't get an alert until right around 20% above or below the recommended PSI. If you have a 250 with recommended 65 PSI rear, I wouldn't expect the alert to come on until around 52 PSI.
They vary a bit depending on wheel size and sometimes option pkg (like Tremor). With 20" wheels on a 250, they list 65 on the rear. No idea what the OP is working with, just giving him an example. Your TPMS light should come on right around 60 PSI.
mebe2k
6.7L Power Stroke Diesel
33
11-15-2015 10:56 AM
