02 f150 5.4 issue
02 f150 5.4 issue
I just bought a truck that I expected to replace the engine on he said it hydro locked and has white smoke out the exhaust so it's been sitting a few years. We bought it today and after jumping started right up and drove it on trailer. We got home, drove it off trailer and drove it like 4 miles, no problems.
I heard that the 5.4 has a few issues including a intake issue, what are the symptoms of that intake issue, could that be the whole issue? I was going to do a compression check
Yes, the manifold water crossover leaks with age on some. Both my 01 5.4s had this, built late 00 if helps.
Dorman one is garbage and has a tiny plenum area compared to OE, plus the cost is a wash nearly. Figure about $400 all said and done with HD Felpo gaskets, new Ford manifold, water pipe, knock sensor, and coolant. Plugs are a BREEZE if it is off. Fan belt comes off, so eyeball it, tensioner, and idler.
You will spend more time cleaning than pulling the thing. This is if that is your issue.
Thanks everyone I didn't think of the crossover tube and knock sensor, I'll change those as well after I return the dorman and get motor craft intake. The worst case scenario, it still don't work then I swap the new parts into the replacement engine. I'll do a compression test and stick a camera in each cylinder and let everyone know the verdict
Around that time Ford swapped to PI heads, so I cannot tell you exactly when. Someone else will know for sure.
Pal's '00 Expedition 5.4 has plastic intake and PI heads, so I am guessing '99 and older had the aluminum. Again, wild *** guess. Maybe compare intake gasket part numbers online to narrow it down.
I'd examine the spark plugs before firing parts at it based on assumptions. Maybe also check the coolant for combustion gases. Could be a head gasket. That might show up on a single cylinder, where a coolant leak in to the intake manifold would probably show on several. A cylinder pressure test is easy too, and would be a clue. Quite a few simple things to do before swapping parts. Good luck.
