2023+ 7.3 No More Messy Oil Change
I've had this sitting in my toolbox for a few months now and finally installed it yesterday when I changed the oil (won't get into what oil I filled it with lol). I like the design of this valve because it has a cap sealed with an o-ring and in theory, when I change it next I can just hook my John Dow oil extractor right up to it with the drain adapter it came with and let the extractor draw the oil out without even having to drain it into a pan. Torqued it to 15 ft/lb with no drama, checked that it was snug in both directions with a wrench, put the cap on and all appears to be good.
It's a Stahlbus drain valve. I chose this instead of the Fumoto because you have to get the adjustable position valve in M12X1.75 to clear the recess where the drain plug is, and that valve only comes with a very short nipple.
Yes, you can cover the transmission cooler with butcher paper or aluminum foil. I didn't want to have to keep doing that.
The following 5 users liked this post by saratoga2011:
Never seen one before, any concern with the ball bearing inside breaking free into your oil pan? I like the idea because when I changed my oil for the first time myself I had to use a wrench the whole time to get the plug out, not sure if someone screwed the threads up in the pan or the plug.
Thanks
Thanks
M14-1.50 Quick Twist Valve with Stainless Drain Tube **** – ValvoMax Oil Drain System
This is what I purchased for my 6.7 truck but have yet to install. Love the concept but my only concern is if I have someone else perform the oil change, like the dealer, I have to remember to supply them the drain cap and tube. Not a big deal if you store in the truck.
Right, I took it in for the first free oil change but have changed all the rest myself. It would be the just in case scenario. Guess I'll throw it in the next change since the "just in case" will probably never come.
