2023+ Super Duty ForScan Spreadsheet
Old Jan 26, 2024 | 03:08 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
**Things that are not working as of 01-26-2024**
Auto Shutdown Disable
**Things that are partially working as of 04-26-2024**
DTE only increases partially what the gallon/MPG should be. But the DTE does not start to drop immediately
**Notes**
My Screen not returning to last screen is resolved in SSM 51679
Factory (owners manual) method of disabling Seat Belts is resolved in SSM 51679
Ok everyone here is the beginning of the 23+ ForScan Spreadsheet.
I have tried to add all the changes we have done in the other thread. There are more to be added.
I don't have hands on a MY23+, so if someone your like to test things for support shoot me a PM or email if you have it.
ZooDad
Popular Reply
Jan 26, 2024, 03:28 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I want to thank you for all the hard work that you’ve put into this over the years! You’ve improved the ownership experience for thousands of us!
Id love to help out with my ‘24, but I’m not knowledgeable enough about this stuff to fix it if something goes wrong. I can barely do what I want to do following directions from here and YouTube!
Old Jan 26, 2024 | 03:09 PM
ZooDad's Avatar
ZooDad
First place holder
ZooDad
ZooDad's Avatar
ZooDad
UPDATE FROM FORSCAN
ZooDad
Old Jan 26, 2024 | 03:28 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Old Jan 26, 2024 | 03:30 PM
stroke250's Avatar
stroke250
Thank you Sir!
Old Jan 26, 2024 | 03:33 PM
ZooDad's Avatar
ZooDad
@ATC Crazy
Its super simple and I’ll walk you through it. Nothing “crazy” I promise.
ZooDad
Old Jan 26, 2024 | 03:37 PM
robbv's Avatar
robbv
I can test the ones I haven't already done on my MY24 f550 this evening as soon as I charge my computer.
also would like to add disable alarm motion sensors so every time I leave the truck with the dog in it I don't have to shut them off
or else he sets the alarm off
Old Jan 26, 2024 | 04:08 PM
kry226's Avatar
kry226
Exactly this! Thanks, ZooDad!
Old Jan 26, 2024 | 04:23 PM
Rutcutter's Avatar
Rutcutter
Fixing to install a set of 37's on my rig and wanting to adjust the speedo. Whats everyone using for the number? When I click on the Tire Size Calculator it is giving me the error that the file has been deleted.
Old Jan 26, 2024 | 04:41 PM
ZooDad's Avatar
ZooDad
@Rutcutter
The link in the sticky post works fine
You will get a larger that acceptable number for 37’s. Start with 2770 for tire circumference. That will get you close.
ZooDad
Old Jan 26, 2024 | 07:08 PM
kevscamaro's Avatar
kevscamaro
4wd Low
Can you figure out how to enable , trail turn assist, like the tremor trucks have.. i have the button,,,
Old Jan 26, 2024 | 09:08 PM
TJP249's Avatar
TJP249
Once I get my truck back I will be in for some testing. Starting with trying to add SecuriCode keypad.
Old Jan 27, 2024 | 06:17 AM
capt caper's Avatar
capt caper
Drove me crazy too. Couldn't make it default to Perimeter only. Someone said to put a piece of tape over the sensors.
Old Jan 27, 2024 | 06:56 AM
The well guy's Avatar
The well guy
I've purchased a laptop with windows 11 and the OBDLink EX for my 23 Lariat ultimate and 22 xlt. Maybe we can help each other @ZooDad
Old Jan 27, 2024 | 07:18 AM
kylant's Avatar
kylant
can you post where to find the tire pressure converted to hex values?
I can't seem to find them.
thank you
