Ford leaving the CP4
At this point, it would be an admission of guilt. Lawyers are waiting for a super class action on this issue anyway.
Not unless a different pump can NOT be retrofit. I.E. when they do a complete engine re-design. That way all the folks that have had failures with the CP-4 can’’t come back on them and say “I want the new and improved version too……on you”; along with a refund of cost to replace”.
The following 4 users liked this post by Dirthawg2.0:
https://truthinadvertising.org/class...jection-pumps/
Just one article. The lawyers are absolutely salivating over this issue.
Until the lawyers get involved. Then anything can be construed as an admission of guilt.
Once again this has nothing to do with whether or not Ford quits using the CP4.2.
Well, there is a reason GM dupmed it, there is a reason Cummins/RAM dumped it, and there is a reason keeps shoving it down the consumers throat Stay faithful.
Received 1,537 Likes
on
Something tells me part of the reason Cummins got a $1.7B slap down fine from the EPA was because the CP3 might not have been able to meet performance and emissions requirements. At the end of the day, it's the EPA that's driving the decisions on the auto manufacturers. Having said that Stanadyne pumps were used in the International 6.9/7.3 IDI engines so perhaps it's a possibility again???
The following 3 users liked this post by FishOnOne:
Well, the aftermarket already has it figured out and the only way I'd buy another truck, newer than mine, is hitting the lottery.
Nice to know that S&S has a swap in option with that Stanadyne DCR pump... If or when mine goes... It's insanity to think I'd have to pay $30k plus to get the truck I have now...
The only time FoMoCo will move on from the CP4 is when it can no longer meet the necessary specifications. They have been running that pump for almost 13 years (longer than any other version of the PSD was in service), the failure rate under warranty has to be low enough that it is acceptable to them and the threat of post-warranty failure hasn't sufficiently dented perceived demand to warrant a change for them. In Ford's defense, they did a MUCH better job on the low pressure fuel system than GM or Dodge. GM didn't even have a dedicated lift pump for the DMax CP4's and Dodge's lift pumps have been horrid since the 98.5 VP44 trucks, they did improve with the in tank conversions in 2005 but hardly robust IMHO. IIRC, the Ford low pressure system supplies three times the required fuel volume. That said that is little condolence to anyone that had a CP4 seppuku on them. I don't see Ford changing until they have to.
The following 2 users liked this post by Painted Horse:
The following 4 users liked this post by JoeUser:
The whole thing about the CP4 is that it is not a problem for those that have not had a premature failure. When one goes out at 20,000 miles and you arre 1500 miles from home, and Ford has them on national backorder, then they all of a sudden become a huge problem. It sure ruins any faith in a Ford product in a hurry.
The following 4 users liked this post by Desert Don:
The following 2 users liked this post by Overkill2:
