These AGM batteries still recommended?
Old Oct 14, 2023 | 05:48 PM
RaiderBob's Avatar
RaiderBob
Red top optima's used to be recommended but if I recall their quality has gone down? How about these?
X2Power Premium AGM 930CCA BCI Group 65 Car and Truck Battery - SLI65AGMDP at Batteries Plus
Old Oct 14, 2023 | 07:05 PM
4wd6.7L's Avatar
4wd6.7L
Still considered a good AGM option. Made by EnerSys (like Odyssey)now if I'm not mistaken.
Old Oct 14, 2023 | 11:39 PM
aklim's Avatar
aklim
I'm using an Odyssey and so far, it has been decent. Bought it X'mas eve of 22. As long as it lasts for about 3.75 years I'll be good with a new one.
Old Oct 15, 2023 | 08:43 AM
MBuckholz's Avatar
MBuckholz
I just installed a new pair of the group 65 everstart platinum AGM I purchased from Walmart mail order FOR my 2018 F350. They were directly shipped from Johnson controls out of Michigan to Arizona. The packaging with the best box I've ever received, both batteries arrived in perfect condition and I'm super pleased. And the best part was pricing $149.76 each. Upon receipt I charged both of them fully, load tested them. They are working perfect. After I pulled out the leaking OEM batteries, I baking soda the clamp system and the boxes they sat in, and repainted the clamps with some rustoleum black paint. Slid the insulator covers off the stock batteries and put them on the new everstarts. They should be good for a long long time and no acid leaking
Old Oct 15, 2023 | 10:08 AM
orbsah's Avatar
orbsah
I saw a question a while back asking if changing to AGM batteries requires a Forscan software change. Is that valid?
Old Oct 15, 2023 | 10:14 AM
aklim's Avatar
aklim
I'd be curious since I have not done it yet
Old Oct 15, 2023 | 10:42 AM
Rich1961's Avatar
Rich1961
Arod has a video of his AGM Battery installation in his personal truck, and it shows him going into the BCM to change the charging profile to AGM.
Old Oct 15, 2023 | 11:35 AM
4wd6.7L's Avatar
4wd6.7L
That might depend on what year of SD. My 2019 came from the factory with battery monitoring system= none, and battery type = not configured. I left it as is after installing AGM batteries. I haven't experienced any problems and it charges at the correct voltage for an AGM battery. I did do the BMS reset procedure just for the hell of it.
2020+ do have a different battery monitoring system than earlier years. But, there have been 2020+ owners who made no setting changes and didn't have any issues as a result.
Old Oct 15, 2023 | 06:23 PM
morehouse7's Avatar
morehouse7
Ditto on my 17'. Odyssey AGM, I didn't BMS reset.
Old Oct 16, 2023 | 11:31 PM
9Mile's Avatar
9Mile
i put a set of those in last year. No complaints.
Old Today | 06:54 PM
jwith's Avatar
jwith
1st Gear
Post
My 2018 F-350 batteries finally died this week after a cell shorted during a start. I previously ran a pair of Duralast Gold 850 CCA batteries that lasted over 5 years.
I just replaced them with two Walmart EverStart Platinum AGM batteries (WAGM65).
When checking the Body Control Module (BdyCM) via FORScan, I noticed two things:
  • BMS (Battery Management System): Set to disabled/not installed.
  • Initial Battery Type: Set to 34 - Exide 60Ah 520CCA H5 Case.
Since I installed AGM upgrades, I changed the Battery Type setting to 1 - AGM 70Ah 600CCA H6 Case. However, I am considering changing it to 2 - AGM 80Ah 700CCA H7 Case to better match the new capacities.
Has anyone else adjusted these specific settings in FORScan for an AGM swap? Did you change the battery type? Or just leave it?
RaiderBob
6.7L Power Stroke Diesel
39
May 10, 2026 06:21 PM
FishOnOne
2022+ F-150 Lightning EV
29
Jun 6, 2023 04:34 AM
FONRDAY
Feb 12, 2023 11:39 PM
DrCharles
Dec 11, 2021 10:27 AM
tndiesel
Jul 2, 2007 08:31 PM
