died while driving, electrical smoke from dash
Hi -
I'm new to the forum and I'm a stumped (I've poked around the existed forums to see if anyone's had this problem, but nothing seemed to come up). I've got a '92 F150 with a 4.9, 5 speed with a billion miles on it. I started it up the yesterday, started down the road and then it suddenly died. It rolled to a stop and I noticed smoke coming from the driver's side of the dash and the smell of electrical wires. Tried starting it again, it turns, but won't start. The only thing I'd noticed about it recently was that my blinkers stopped clicking - the turn signals turned on the lights, but they didn't blink. Didn't worry much about it as it's basically a back country road truck that doesn't have much need of blinkers. I pulled the dash cover, but I can't find any obvious signs of melted wires, etc. Any ideas of what I should look for and begin to diagnosis this? It would be great to get this thing solved as the truck's sitting in a buddies driveway. Thanks!!
Oftentimes what people call a "short" is really loose, missing, or corroded ground points, cables, and connections. A toasted lightswitch falls into that category, and so does the turn signal symptom you describe. Those cables are approaching 30 years old. I would doubt any of the main connections and grounds have been cracked open and cleaned in all those years? If the cables are original, or even just old, they should be replaced. Low voltage, high current wiring doesn't like any resistance. Even an invisible, paper thin layer of corrosion at a connection is enough to cause major trouble.
Absolutely - don't get wrong, I'm putting in a new headlight switch and, once I can get the thing started, track down the blinker issue too. Having pulled the dash and looked at some of the dash wiring, the only thing I found the really looked obviously fried was the light switch. I checked the ground by the battery, which was fine - the ground to by the starter was a touch loose. I cleaned that and tighten it up too, just for good measure.
