66 speedo cable and gears
Ok I’ve been dealing with my speedo being off for awhile and am getting tired of using my phone as a speedo. I have a 352 with a 3 on the tree. What cable will I need and then can I buy all the gears so I don’t get the wrong one and have to wait more days to get another. Part numbers would be great. Thanks
Also need the rear axle ratio and the original bias ply tire size.
Its a F100, 2wd 3 speed with 3.25 rear end. No clue on original tires. Didn’t have originals when I got it. If the gears are color coded, I have the green, lime colored one.
How do you know if the DRIVEN gear that your truck has is the original or not? Is the speedo reading slow or fast?
The DRIVE gear is 7T steel (C3OZ-17285-C). Haven't got around to the DRIVEN gear yet.
Speedo Cable is C5TZ-17260-N 64.80" long.
I'll finish this up tomorrow. I've been on here all day, haven't eaten yet.
I'm going to assume that the original bias ply tire size was 7.75 x 15, because this was the size on my 1965 F100 352 8' Styleside Dana 44 3.54-1 w/stick and over.
C5TZ-17260-N .. Speedometer Cable & Housing Assy - 64.80" long / Obsolete
1965/66 F100 with 3 M/T and New Process 435 & Warner T-18 4 Speeds.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
HILLTOP CLASSICS in China Grove NC has 2 = 760-746-0400.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 33 = 800-476-9653. These might be repros.
C0DZ-17271-A (replaced C0DD-17271-A) .. Nylon 16T Speedometer DRIVEN Gear - Wine color / Available from Ford (MSRP: $5.24) & auto parts stores.
1965/66 F100 3 M/T & 3.25-1 with 7.00 x 15 bias ply tires.
CARPENTER has 75.
C3DZ-17271-C .. Nylon 17T Speedometer DRIVEN Gear - Green or White color / Available from Ford (MSRP: $5.49) & auto parts stores.
1965/66 F100 3 M/T 3.25-1 with 7.75 x 15 & 8.15 x 15 bias ply tires.
CARPENTER has 103.
C3OZ-17285-C .. Steel 7T Speedometer DRIVE Gear / Obsolete
1965/66 F100 3 M/T 3.25-1 w/all 15" bias ply tires / Misc: 1960's Ford/Merc Passenger Cars.
NOS PARTS SOURCE has 1.
MUSTANG'S ETC. in Van Nuys CA has 2 = 818-787-7634.
HILLTOP CLASSICS has 3.
If your truck has a 17T DRIVEN gear and you install the 16T DRIVEN gear, the speedo will speed up by 5-7 MPH
CARPENTER has 75.
CARPENTER has 103.
CARPENTER has 75.
CARPENTER has 103.
Cosmo
The first letter is the decade: B = 50's, C = 60's, D = 70's, and so forth.
The second digit, denotes the year within that decade.
The part numbers given were all from the 'Slick' era.
Cosmo
They may have been used in other years, but I gave you the applications that apply since you have a 1966 F100 2WD
I don't give a **** what Carpenter lists, I go by what Ford says.
Pic: 1964/72 F100/1100 Conventional Cab BULB CHART:
The part numbers I listed came from the 1964/72 Ford Truck Parts Catalog and are listed for 1965/66.
hest_c
06-27-2016 10:43 AM
Williamzooker
01-09-2010 08:12 PM
