Broken fuel filter disconnect
I was doing my first fuel filter change and all went well until the smaller quick connect did not want to disconnect and I managed to break the connector off at the fuel line. I went old school and was able to reconnect with a little creativity, but obviously need to get a new connector. Am I going to be able to get just the connector or am I in for a major replacement.
Also, has anyone else had a problem with this connector, I still cannot get it to release.
Thanks
Thanks
Thanks
Thanks
Received 6,693 Likes
on
I ended up having to oder a replacement fuel line, it is the high pressure feed rail tube. The price was $116. They were back ordered with 500 expected to ship today so I apparently was not the only one to have this problem, For reference, the part number is HC3Z-9A564-A
As tempting as it was to replace the truck as some had suggested, the wife wouldn't go for it.
OK, so you can buy just the connector. It's on Amazon for $21. Part is
As for disconnecting it from the filter barb, it's a TWO part process. Part 1 is to release the red tab by sliding it upward. Then you SQUEEZE on the sides of the connector...there are black plastic squeeze tabs that come into view when you release the red tab. Comes off easily when you squeeze the black tabs and then pull. Pull the connector and NOT the hose.
HC3Z-9A564-A.
HC3Z-9A564-A.
Better late than never I guess. Hopefully in the 3.5 years since posting, they figured it out.
HC3Z-9A564-A is a Ford part#, and it is what the OP purchased (post #10) for the repair. However, the Ford part associated with that # is not simply just the connector. As stated by the OP.
There are various aftermarket options to make the repair, like the one you found on Amazon for $21. Using that Ford part number does help pull up those aftermarket options.
CWR032
20
12-19-2016 10:49 AM
whoaf150
12-09-2014 08:37 PM
luke_trash
06-27-2003 10:11 PM
