First time was fuse #4 or 5 under the hood. Both light up as working when tested. Do you normally have a buzzer when you open the door with the key in or the light on?
First thing is cruise deactivation switch on master. If that switch is "open" no cruise and they tend to be failure prone. Check inside switch connector on switch for brake fluid.. also do you have the recall harness at said deactivation switch?
do brake lights including third lamp operate?
3rd brake lamp works. There is fluid in the switch connector at the mc
those harnesses have a fuse. When the switch gets wet that's what burned trucks down. Hence the jumper harness with fuse. I believe you have found your issue
Ok. So how do i go about fixing this? New harness (mine says there isnt a fuse in that harness.) Do i need a new switch since this ones leaking? Lol help me out here. Im about as electronics savvy as a cave man.
