Go Back  Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Reload this Page >
Cruise control wont work.... again.
Old 02-17-2019, 12:56 PM
Ezalycasaid's Avatar
Ezalycasaid
Ezalycasaid is offline
Ezalycasaid is starting off with a positive reputation.
Ok so where do i start with this stupid thing? 97 Obs extended cab 7.3 auto 4x4. Cruise stopped working. Checked fuses. Checked all lights. Now what?
Old 02-17-2019, 01:28 PM
Hussler's Avatar
Hussler
Hussler is offline
Hussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to behold
What fixed it the first time? You indicated again.
Old 02-17-2019, 01:31 PM
First time was fuse #4 or 5 under the hood. Both light up as working when tested. Do you normally have a buzzer when you open the door with the key in or the light on?
Old 02-17-2019, 01:47 PM
Hussler's Avatar
Hussler
Hussler is offline
Yes, buzzer (chime) sounds with key in and door open or lights ON with key out and door open on my 97.
Old 02-17-2019, 01:53 PM
interesting. Mine does not
Old 02-17-2019, 02:28 PM
fordman67's Avatar
fordman67
fordman67 is offline
fordman67 is a name known to allfordman67 is a name known to allfordman67 is a name known to allfordman67 is a name known to allfordman67 is a name known to allfordman67 is a name known to all
First thing is cruise deactivation switch on master. If that switch is "open" no cruise and they tend to be failure prone. Check inside switch connector on switch for brake fluid.. also do you have the recall harness at said deactivation switch?
do brake lights including third lamp operate?
Old 02-17-2019, 02:30 PM
My ebrake indicator light wont come on when iys engaged as well
Old 02-17-2019, 02:35 PM
fordman67's Avatar
fordman67
Mine has not worked either lol
Old 02-17-2019, 02:37 PM
3rd brake lamp works. There is fluid in the switch connector at the mc
Old 02-17-2019, 02:40 PM
Old 02-17-2019, 02:41 PM
Lots of fluid
Old 02-17-2019, 02:44 PM
fordman67's Avatar
fordman67
those harnesses have a fuse. When the switch gets wet that's what burned trucks down. Hence the jumper harness with fuse. I believe you have found your issue
Bumper side brake lights work as well
Old 02-17-2019, 02:45 PM
97-psd's Avatar
97-psd
97-psd is offline
97-psd has a good reputation on FTE.97-psd has a good reputation on FTE.
That one is broken.
Old 02-17-2019, 02:47 PM
Ok. So how do i go about fixing this? New harness (mine says there isnt a fuse in that harness.) Do i need a new switch since this ones leaking? Lol help me out here. Im about as electronics savvy as a cave man.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
