e250 Vacuum issue and vacuum canister replacment
Old 02-17-2019, 07:34 AM
jayro88's Avatar
jayro88
jayro88 is offline
So a while back my vacuum pump froze up and died. Prior to that I had no vacuum issues. I replaced the pump, but it never seemed quite right. When it was really cold out my brake light would come on at idle and my peddle would be hard. Since everything was fine before I thought it might be the old hose coming off the vacuum pump had a tear or wasn't sealing correctly. Yesterday I went ahead and replaced the hose and put clamps on each end. I am still having the vacuum issue. I have ordered another replacement pump to install and am thinking that maybe the new one was bad/weak out of the box. While I am at it I was thinking of maybe replacing the vacuum reserve canister (looks like a coffee can) that is located in the passenger side fender next to the battery. A quick search isn't bringing up a stock replacement. I found some universal replacements, but I was wondering what everyone else is running?
Old 02-17-2019, 10:37 AM
jayro88's Avatar
jayro88
jayro88 is offline
Would this work?
JEGS 63010 Vacuum Reserve Canister https://www.amazon.com/dp/B078WJXZY5/ref=cm_sw_r_cp_api_i_i0yACbDAHYFAQ
danlee
1999 to 2016 Super Duty
03-23-2017 09:27 AM
danlee
03-21-2017 08:25 PM
handyjohn
15
08-12-2014 04:35 PM
pmoney1983
01-16-2013 03:57 PM
my4604x4
09-03-2008 07:52 AM
Quick Reply: e250 Vacuum issue and vacuum canister replacment
