so I bought a power brake booster to bolt in under the floor like stock YEARS ago. So I am close to runnng the lines and I can’t find the paperwork- and I don’t remember if the front comes off the front of the booster or the rear?
I look on most all of mine and if is back for front and front for back. Of course if you have disc you need the proportional valve and you need the residual valves since its below cab. Mine cross from MC to proportional valve then go forward and backward.
thanks- I know (will double check) I have the proportional valve for 4 wheel disks, I am not sure if I knew about the residual valve tho-
i am running brake lines up the driver side frame rail and fuel up the passenger side-
i need to look at where the valves fall in the lin-up now-
i have the CPP version with prop valve and there are two fitting for front on front of prop valve and one larger fitting for rear of the back of prop valve.disk front and rear
