Brake Proportioning Valve
Early 2000's crown vics (including 2004) with anti lock brakes started using Electronic Brake Distribution, where the computer did the brake proportioning. If you are not using this system in your swap you will need a "mechanical" proportioning valve. This one seems pretty popular:
The front and rear valves on the booster are different, but this has to do with the primary and secondary pistons.
Electronic Brake Force Distribution (EBD) | Hendon Publishing
2004 Ford Crown Victoria Police Interceptor Master Cylinder Pictures
Da_Lariat_Chariot
01-26-2019 08:57 PM
1956in1956
10-02-2015 09:29 AM
