Need help decoding vin#
Hey All,
Just joined today. Currently I'm looking into buying an old 1966 Ford T850 Super Duty and restoring it. I've been having a hard time decoding the vin. I was looking through different forum posts and have noticed that members here and a wealth of knowledge in that area. Hoping you could help me out.
Vin # T85KUA15449
Any and all info you could supply would be Mich appreciated! Trying to ensure this is what I want before I buy it.
Thanks,
Caleb
Vin # T85KUA15449
Thanks,
Caleb
T85 - T850 (Gas)
K - 477 Ford 8-cylinder gas 4V
U - Louisville, KY assembly plant
815449 - 1966 - Assembled December 1965 - I figure the "A" is a stampo.
158" Wheelbase.
A - Raven Black Color code
T850 - T850 39,000 Lbs GVWR
E81 - E = Red crush vinyl and red cody pattern woven plastic - 81 = 81B - Custom Cab
Blank Transmission code - indicating possible special order
Blank Axle code - indicating possible special order
39,000 lbs. Gross Vehicle Weight Rating.
222 net HP @ 3,200 RPM
61 - Dallas, TX District Sales Office
0015 - Domestic Special Order number
Does this truck have a bench seat in it or does it have the Bostrom Viking suspension seat for the drivers side?
Chad
158" Wheelbase.
Chad
Thanks NumberDummy for the clarification on the year. It looks to be what I'm looking for as I can't find any t950's so far. The t850 I'm looking at is a good 5.5 hrs away so I'm trying to get all the info I can before I make the trek. Doesn't look to be in running condition but I can't complain about the $800 asking price. It's a cheap way to get into these awesome trucks.
Thanks NumberDummy for the clarification on the year. It looks to be what I'm looking for as I can't find any T850's so far. The T850 I'm looking at is a good 5.5 hrs away so I'm trying to get all the info I can before I make the trek. Doesn't look to be in running condition but I can't complain about the $800 asking price. It's a cheap way to get into these awesome trucks.
1967/69 F800/1000 & T700/950 use the same cab as 1961/64 F100/1100; 1965 F100/250 4WD; 1965/66 F350/1100; 1966 F250 4WD
The doors, all the glass and the weatherstrips are the same as 1961/66 F100/1100 (doors: except 1961/63 F100/250 Uni pickups) & T700/950.
The weatherstrips are reproduced, but the repro parts sellers only list them for F100/350, as this is what most people have.
Please post further questions in the LARGE TRUCK forum.
Don't be deceived by a low asking price. Big trucks means big parts which means big money. If you are in the business you probably know this. Don't ask be how I found out..Sometimes the seller could give the truck and $5,000.00 and you will come out on the short end of the stick. As suggested in post 2 if the transmission and rear are vendor parts you may be able to get parts through the vendors if they are still in business.
I appreciate the warning shadyside1983. I currently have a 1995 Ford CF8000 20ft flatbed with an 8.3 Cummins and my class a cdl. I want a truck with a higher gvwr/gcwr and a shorter wheel base. I've also always wanted a classic vehicle so I'm planning a full restomod to get both. It'll take lots of time, effort, and money but that's what I'm expecting.
Chad
F10 = F100 2WD
Y = 352 2V
K = Kansas City MO Assembly Plant.
872047 = 1966.
VIN when decoded, doesn't tell you much. Post a pic of the Warranty Plate, riveted to the left door face below the latch, or type the info.
Y = 352 2V
872047 = 1966.
Df0605
07-30-2018 07:52 PM
