Stanley Fatmax 1000a jumpack 6.2L gas
I had a 800amp peak one for my truck a 5.4 and it puffed after 2 or 3 jumps. You would only get one to two chances to get it started but if it was dead it would over draw. I picked this one up instead. Its 1000amps starting. Little pricey but my battery is 930amps so this should do the trick
Suaoki U28 2000A Peak Jump Starter Pack (for ALL Gas or 8.0L Diesel Engines) with USB Power Bank, LED Flashlight and Smart Battery Clamps for 12V Car & Boat
As luck would have it, went to start my 2006 F350 5.4 yesterday and it was completely dead. Use it mainly for plowing, but try to drive it once a week during the summer.
Hooked my NOCO GB 150 jumper to it and it started right up. (Have the 150 series because I wanted to make sure it would handle a frozen diesel skidsteer in the winter). GB 150 was still almost 100% after sitting in the cab all summer and barely dropped after the jump.
Had a tbc fault on the truck after starting. Have alot of rust on the truck; had plugged a reverse light into the trailer plug last week and it pushed the plug in (light didn’t work). Turned out one of the plug wires was cracked and evidently shorted out and drained my battery.
JPMallory
06-17-2019 02:49 PM
crazycd1
10-17-2012 02:21 AM
john fin
32
03-11-2012 04:44 PM
