Sponsored by: Auxito
Electrical issues(battery drain)
Old Apr 24, 2018 | 06:36 PM
Joshua Ellis Dumas's Avatar
Joshua Ellis Dumas
I’ve had my 99 f350 for 2 months it has the v10 triton 6.8l. It has seemingly just had a bad ground pop up to where if I hit any button(with brand new fully charged battery) it instantly drains the battery to almost nothing. If I try to start it nothing, I’d i hit the power windows it drains. I have replaced the starter and alternator, the battery and terminals all brand new. I’ve checked all fuses. Could it be a ground to the frame, or something much larger. Like I said I pulled in **** it off, went to start it again and nothing happened it won’t even get enough power to try and start( with new battery). Any help his desperately appreciated.
Old Apr 24, 2018 | 08:44 PM
projectSHO89's Avatar
projectSHO89
That would result in smoke and fire if you discharged a fully charged battery in that short of time.
Sounds more like you have a simple problem of a bad battery, battery connection, or battery cable/connection. Use common voltage drop troubleshooting to isolate.
Old Apr 25, 2018 | 09:37 AM
alloro's Avatar
alloro
Did you replace the correct battery, it's diesel so you have two of them, correct?
Old Apr 25, 2018 | 12:01 PM
Bluegrass 7's Avatar
Bluegrass 7
V10 is not a Diesel.
It's an overgrown 5.4 10 cylinder gas engine.
Good luck.
Old Apr 26, 2018 | 02:43 PM
alloro's Avatar
alloro
Good luck.
Yep you're correct, it's the 6.7L that's a diesel not the 6.8L and I overlooked the V10.
Joshua Ellis Dumas
Modular V10 (6.8l)
Apr 24, 2018 08:51 PM
Joshua Ellis Dumas
Apr 24, 2018 08:47 PM
gweeds
Mar 30, 2008 08:40 AM
97 RED PSD
1997 - 2003 F150
Dec 21, 2005 12:01 AM
Bobtailfan
Electrical Systems/Wiring
Sep 7, 2004 09:50 PM
