Ford engine management software won't let you harm your engine. Pedal to the metal is perfectly acceptable. I'm also curious what Class A is using the 6.7L.
My tach doesn’t have any red line and goes up to 6000. I’ve never let it get past 4500 - then only briefly - too loud and wasn’t sure what that was doing to the transmission. I have a gas V10 in a Thor 2014 Hurricane 27K.
The reason we're asking about the engine is you posted your question in the diesel 6.7L forum. You might want to repost in one of the gas engine forums, or ask a moderator to move this thread.
Well you got the wrong forum but 4500 rpm is not near max rpm for the v10. Many of us run them at WOT at over 5000 rpm up hill just fine. At 4500 rpm you aren't even getting full HP.
I've traveled all over the US towing a large fifth-wheel trailer with an F-350 V-10. They like to spin, both going up hills and coming down (tow/haul mode engine braking). I've seen over 4500 rpm a number of times, especially when descending a steep grade. The engine computer will take care of the engine without you needing to worry about a "not-to-exceed" RPM. The V-10 is a great engine, but it needs to turn a lot of RPM's in some situations.
