Mercury GM Cruise Control
Is there any chance that you folks might have some information on troubleshooting a 2002 Mercury GM? Wifes cc has been out for awhile and I haven't been able to discover much troubleshooting information on it. I can tell you that the horn and the hazard lights are all functioning correctly and from what I can tell the brake switch is testing well because it was removed and put a meter on it. Just don't want to start throwing parts at it if I can avoid it. Any advice would be appreciated.
The car does't have one, it does however have a standard brake pedal release switch which tested fine when you pull it out and probe it. If the brake switch was intended to have a plunger pad on it, which the car doesn't seem to have now that could be the issue but I have no way of knowing if it did. The cruise module has 12 volts when the 'on' button is pressed but quickly goes away after releasing. Guess I will continue to test.
