DRL + Tail lights (Forscan?)?
In case no one has noticed, when you have the lights in "full auto", you get DRL when in drive during daylight. HOWEVER, there are no tail lights. My SO says this is a safety issue, and she insists that I turn the headlights on so that we do get tail lights. I think it's kind of a bother, and would prefer that the DRL included tail lights on.
Then I thought, oh maybe there is a way to turn on the tail lights if the headlights are in DRL mode with Forscan?
I don't know if this is approved or not, so if a moderator is looking and I'm screwing up, go ahead and slap me. I found this complete thread on all the ways to adjust what happens in DRL mode on the F150 forum: https://www.f150forum.com/f118/setti...80225/index13/
Phase II started circa 2005-2008 when some vehicles would turn off your headlights for you (Toyotas come to mind). That worked pretty well, as you could just leave the headlights on all the time. Our 2012 Tacoma does this, and it turns the headlights off when you open the driver's door. If you don't open the door, or if you happen to turn on the ignition through the window, you're screwed.
The "full auto" DRL on our 2015 F-150 is great, except that the DRL does not include tail lights. Not clear on the thought process. It is nice that the headlights operate at reduced intensity, but in reduced visibility situations when you need a little visual help, but not full headlights, it would seem to be good to have tail lights too. When I'm driving down our mountain road in the fog during the day, I have been caught coming up on someone driving slower in front of me, but didn't see them well enough because there were no tail lights.I haven't actually hit anyone, but I'd sure like a little more margin.
Here is the complete Forscan decoder ring for adjusting the way the DRL works. I did a mostly cut & paste from where I found this the first time. There are actually 3 places you have to adjust, 726-45-01, 726-50-01, and 726-26-02. The first one (726-45-01) removes restrictions on the way DRLs work. The second one (726-50-01) also turns on the front parking lights. The third one (726-26-02) enables the parking lights with DRL. Note that there are other options that would allow the (for example) Anzo Switchback lights to operate in halo mode.
Allow All Alternate DRL Options (Restrictions Removed - No Invalid Configuration Errors):
BdyCM (As-Built Modifications)
Allow All DRL Choices:
726-45-01: xxxx 7Fxx xxxx
Enabled DRL Selection:
726-50-01: XXxx
XX:
01 = Disabled / Parking Lights Only (See change below)
02 = Low Beams
04 = Front Fog Lamps
08 = Front Turn Lamps
10 = Dedicated DRL Lights (LED Light Bars/Strips) - Enables BCM DRL Outputs - C2280F (F-150) Pins 36 (Right) and 40 (Left)
20 = High Beams
40 = Low Beams and Dedicated DRL Lights
Optional: Enable DRL Parking Lights:
Can be combined with other DRL options above
726-26-02: x1xx xxxx xxxx
Optional: Disable DRL Switchback w/Turn Signal:
726-26-02: xxx0 xxxx xxxx
On/Off for these is controlled from the Instrument Cluster DRL Control.
I know many of you change wiring and such to accomplish some of these which can be now changed in seconds... so enjoy!
726-50-01: XXxx
XX:
02 = Low Beams
20 = High Beams
steuspeed
07-29-2016 04:12 PM
