2000 V10 shuddering under load
2000 V10 motorhome 46,000 miles no check engine light , it has been running fine up until today. First 30 miles of trip had plenty of power up hills on Interstate, slowed way down to change Interstates, accelerated to merge and it immediately started stumbling which it has never done before. Fought with it for about 100 miles trying to find a sweet spot for going up the hills with it stumbling and stuttering up the hills. At one point I ran it up to 4000 rpms to get up one hill. It runs fine on the level or very slight inclines I can hold 60-65 without issue on the level but any real incline and it starts stumbling and might get down to 40 mph .....this on I89 in VT so not really any steep inclines . Dropped off Interstate into town, from a stop it stumbles a bit until I get the revs up above 2500
I'm thinking I'll dump some Seafoam into the tank and fill it up for the trip home and see what happens, this also happened after I filled the tank just before this trip from about 3/4 full but it did run fine for about 30 miles. My friend thought dry gas might help if it is water in gas
Any thoughts ?
Any thoughts ?
Could be any of a few things from low fuel pressure, bad gas, partially clogged cat, ....
First thing I would check is the plug boots, have they ever been changed?
I change plugs/boots at 50k, but yours might have 18 years on them.
If your loss of power under load is misfiring it probably will not set a code even after many misfires.
The misfires can be seen in raw data from the computer using a bluetooth OBDII adapter and a program like Forscan which are relatively inexpensive.
it did set a bunch of codes probably because it was misfiring so bad. I bought some Lucas fuel cleaner and will try that on the way home and hope that takes care of it.
Random misfires
Cyl #1 misfires
Cyn #5 misfires
U1D03 couldn't find that one
P0603 PCM KAM test error
P0900 Clutch actuator open
P000D Camshaft position slow response
plug boots haven't been changed , perhaps I should order a set ....I guess they must be separate from the COPs ?
Random misfires
Cyl #1 misfires
Cyn #5 misfires
The Denso boots/springs are $30 for 10 on ebay.
Motorcraft SP479 plugs are also $30 for 10 on ebay.
If you change the boots and do not change the plugs at least retorque them 20-25 ft-lbs.
The OEM plugs are only torqued to 11-17 ft-lbs and have a tendency to work loose around 100k and strip the threads.
That strange bunch of codes points to low voltage and/or a bad alternator because they are all unrelated. Clear the codes, and see if they show up again. Also, try a different scanner. Got a volt meter? Check the battery voltage with the engine off and then idling, and report back. Fully charged battery should be around 12.6 volts, and idling, should be 13.5-14.x
Something's weird.
However, it could just be a COP arcing (or not arcing at all) and the feedback from the coil is causing the PCM to freak out. Check the voltage like I said above, and if that checks out, pull #1 and #5 COP and see what's going on.
Something's weird.
Battery voltage engine off 12.8 running 14.2 I cleared the codes . and they didn't return on the return trip but I did have a a slight amount of stumbling on the return trip.
dumped in 2 cans of Lucas Deep clean and filled up with hi test. I kept the OD off for the first 10 miles and it was fine, no problem running at 3000 rpm which is about 50 mph., Kicked in OD , was good for about 70 miles running 60 - 65 mph no problem and got behind someone going a little slow, lost momentum and it shifted down, up to 3500 rpm no problem, it dropped down to 3200 (torque convertor locking back up ?? ) and started stumbling, backed off on the gas pedal and it smoothed out. Was Ok the rest of the trip until a steep hill by our house , I foolishly left it in OD as I wanted to see if it would pull it over the hill, big mistake ....started stumbling and wouldn't downshift, kicked off OD but didn't help .....I didn't want to manually downshift so i let off and crept over the hill. It did not set any codes.
Here is the crazy thing , my son said his car started doing the same thing on sat but he bought gas 30 miles from where I got mine
Random misfires
Cyl #1 misfires
Cyn #5 misfires
Random misfires
Cyl #1 misfires
Cyn #5 misfires
If you are having misfires you may want to chaange the plugs, and boots as mentioned earlier ITT. I always carry a Denso COP in my truck and have an extra at home in a box.
Has your fuel filter ever been changed? Air filter clean?
I would start with a little maintenance and cleaning.
shudder under load
I was in the process of changing the COPS and found antifreeze in the spark plug wells for cyl 1,2 and 3...turns out the heater hose was leaking just enough to flood those wells. Once I tightened the hose clamp, dried out the plugs, it took care of it
sorry I didn't get back to this thread before
@tiffy2000 How are the shuddering issues-still holding up ok? Just curious, my V10 started doing the same thing. No leaks anywhere into the plug areas though.
Are there any vacuum lines that feel soft, particularly ones that connect to the engine like behind the throttle body?
How many miles since the MAF was last cleaned?
How old are the COP boots, they can age out and arc right thru the rubber without a visible spot.
I change the COP boots at 50K along the spark plugs, they are available separately, the COP coils will far outlast the boots.
Is it shuddering while accelerating or shifting gears?
Is your "shuddering" a misfiring/pulsing or generally running rough?
It shudders-jerks-like it loses power for 1/2 a second, guess you could describe as a misfiring cylinder mostly when going up a hill under constant load. Not when shifting. Had transmission rebuilt just a few months ago and it seems quite fine.
Some test equipment can tell you if there are occasional (pending code) misfires on a particular cylinder which isn't setting a code.
It takes a lot of misfires to set a code, especially if they are intermittent.
Once a suspect cylinder(s) is found then you can zero in on the COP coil or boot, plug, water intrusion, loose/corroded connector pins, multi strand power wire with broken strands, poor electrical grounds, clogged fuel injector filter screen, ....
The PCM is connecting the spark plug and fuel injector circuits to GND when it is time to fire a plug or open an injector so good GND connections at the PCM are necessary.
