Getting the “Green Mill” running again 1974 F250
I attached a photo of the “Green Mill” coming off the delivery truck from California. 1974 F250 2wd SuperCab, 390 FE with a Holley 4 banger. Only a little over 12,000 miles (I hope) Has been sitting in the family’s garage for many years. I call the Truck the Green Mill because it’s green, and the Green Mill is a great vintage bar in Chicago’s Uptown neighborhood that I used to enjoy going to. It’s like going back in time to the 1920’s. Everything is original. A real old time Chicago gangster club. Anyway the truck looks pretty good, no rust, all original and straight as an arrow. My first issue was to find V belts because there were none on it. I got some help figuring out how to dertermine what belts to buy from 2 fellow FTE’s. I will try and get them on in a few days. Then I need to drain and change all the fluids and replace some basic ignition parts. Can anyone tell me what do set the new points at? I pulled the plugs today, only broke one and installed new plugs. Just regular copper plugs for now. I really just want to keep the truck as original as possible and get it running as good as I can.
i will keep you posted if your interested and look forward to all the good comments and suggestions from my fellow FTE members
Winched down off the truck
I am sure that is the only way they can be run and not be cocked in the grooves.
Also to get a V belt to grab, aka not slip & not make noise the belt has to wrap around at least half but more if you can.
Now on high power things like AC compressors & 3G ALT. they need 2 matched set of belts.
Dave - - - -
Dave - - - -
There are two versions of the AC- factory and dealer installed. Do you have the giant air box in the engine compartment? If so, that is factory. I believe the belts are supposed to be the same, but it might not hurt to ask the parts guy. The other issue I found is there are about 13 variations on the belts. Took me two tries to get the right PS belt. Haven't got the AC installed and operational yet, but I am sure that will be an adventure for belts as well.
Tried to start- no luck!
i put the shorter a/c belt on and it still has too much play so I will keep looking for a shorter one maybe 1”-1 1/2”
put new plugs in changed the oil and filter put some gas in and got a new battery
now the moment of truth.....it only cranked for about 3 seconds then nothing it really didn’t turn over just like a single jolt
could this be the starter?
let me know what else it may be
thanks
thanks
