Oil temperature
Oil temperature
I just got my truck out the shop about a month ago. Had arp head studs and gaskets done, new oil cooler, and new glow plugs. Egr is already deleted and welded on both sides. Truck has been running great since I’ve had it except for this past week. Oil temperature was running 20-30 degrees cooler than the coolant temperature and would rise up and down very quickly and would never be at normal. Well today was he first time it got up to normal and actually ran hot enough to have the wrench light turn on. Asked the mechanic who did my truck what he thought and said it could be the sensor. I just thought I would ask on a forum for any other opinions. Oil cooler was oem and had a 3 year warranty so what should I do
If the cooling system was not properly flushed your new cooler may have turned into a filter and is now plugged again. You may be able to back flush it, there are videos on YouTube on how. I doubt that the sensor is the problem although it is possible, check the ECT and EOT after the truck sits overnight or longer, if they read the same you can swap the 2 sensors and see if the problem follows the sensor or stays with the oil temp. I really suspect though that you need another oil cooler.
Side question:
After having the EGR replaced three times (cooler twice) on a 6.0L, I was told to step on the pedal once a month to blow out carbon build-up. That worked, and I never had another EGR problem.
Is that the same with the 6.7L? I don't ever see any black smoke with the 6.7. The 6.7L has the particulate filter and DEF.. Does that make a difference and if it does, good or bad..
Johnny Bravo 45
06-02-2019 09:25 AM
2006powerstroke90
09-07-2014 11:33 AM
