rattle/knock inside valve cover?
Driving the van over the weekend and it developed a sudden rattle in the valve cover. Fairly loud/extreme so shut it down and had it towed to a shop. They are disassembling now, but what are common failures in the upper cylinder head on the 5.4L? Broken springs or rockers? Push rod? The odd thing is that the engine was running fine otherwise. I wouldn't have noticed any difference if not for the noise.
Any guesses? I should have confirmation late today or tomorrow. :-(
Crazy... just got the diagnosis: There's a baffle inside the valve cover fastened by two 6mm bolts. The baffle came loose and was bouncing around in the valvetrain. Fortunately no damage so just reaffix and put it all back together.
At least that explains why the van still ran with no other symptoms other than noise!
DemonRace6
272
12-08-2011 03:13 PM
