Time-Sert for 5.4
Old May 14, 2015 | 05:38 PM
ugh3012's Avatar
ugh3012
Time-Sert for 5.4
I got my 5553 Time-Sert repair kit. It says that I should take the valve cover off and make sure the valves stem are not dressed to make sure it is closed. That part is easy, but how can I make sure the piston is down and away from the spark plug hole. That way none of the tools will hit when I follow the instructions. I was thinking of putting long screw driver in the hole to make sure the piston is not in the up position.
Old May 14, 2015 | 05:42 PM
clanbree's Avatar
clanbree
Yup. that's exactly how you do it.
I've done probably 200 as a professional tech and had ZERO comebacks. Follow the instructions, you won't fail
Old May 14, 2015 | 08:11 PM
projectSHO89's Avatar
projectSHO89
You have to make sure of TWO things: That the piston is down AND that the valves are closed.
If the valves are open, you will hit one of them with the tool and damage it, causing a new problem.
Old May 15, 2015 | 07:24 PM
ugh3012's Avatar
ugh3012
How do you get the driver side valve cover off the engine. I have loosen all bolts including the hardest one that was tucked in the firewall. The valve cover is tucked in and I cannot get it off. Is there a trick to remove it?
Old May 16, 2015 | 02:07 PM
ugh3012's Avatar
ugh3012
Never mind. Got the darn thing off.
Teutonics
Aug 14, 2018 01:22 PM
mhartiga1
Dec 19, 2016 06:13 PM
phillycincykid
Modular V8 (4.6L, 5.4L)
Oct 16, 2014 11:02 PM
caverjoe
Nov 10, 2013 08:44 PM
sddesigns
Mar 17, 2011 10:41 PM
