Checking in...160/80 woes
on
A big shout out to all the 7.3L guys and the rest of the gang!
I've been away from the site for a bit and away from my Excursion. My health is recovering nicely, still a few months to go. It's only been a year and to call the improvement 'significant' would be an understatement. Working at putting the rest of our lives back together. It's been a whirlwind
Still have not resolved the rebuilt injectors problem, trying to nail down which one(s) are causing the rough idle and I have one with a very loud and noticeable tick when plugged in (I was unplugging drivers side injectors to find the rough one, no luck yet).
The front one, in the cylinder I replaced the cup, has a loud tick to it.
If I can narrow it down, the injector reman guy (Jim) said he'll gladly take care of it. I just am having trouble finding it.
I'm considering buying a 9th injector at 160/80 to start swapping injectors to find the trouble. Unfortunately, they are quite pricey because of the mod (80%).
I tried to capture the sounds on video, but my camera didn't distinguish the higher pitched ticking from the other normal noises. But it is very noticeable with the ear (even my bad ones!), lol.
So that's about it. I wanted to thank all those who called, texted, emailed, PM'd until my box filled up, etc to check on me. And a special thanks to those who were ready to help my wife sell the Excursion if things had gone differently.
Gotta run for now, but I'll get some updates on my Excursion and finding the injector troubles shortly. Until then, keep your diesel dry!
on
I really appreciate it all, guys. Now I just gotta get this Excursion whipped back into shape as a second vehicle. For a while I couldn't even make it to the garage, but last night I popped that hood in the driveway and pulled the drivers side valve cover without much effort. Notice I didn't say "the crappy side"....er....passenger side, LOL.
The Excursions have that extra bump out from the firewall that makes the cover particularly finicky getting it in and out. I usually just pull the AC and scoot it out of the way a bit.
If the rain lets up, I might pull that cover tonight and see if my phone picks up the high pitch ticking.
Glad to hear you're feeling better!
I also have a loud tick (replaced ALL my cups and 8 injector hold-down bolts). The tick was only noticeable at idle but grew to be noticeable even at speed around town (~35 mph). Pulled the VCs (have to really work at the passenger's one since the lower alternator bracket makes moving the A/C bracket beyond a PITA). All lower injector hold-down bolts were loose (at least 1/4 turn). I'd only put about 5K miles on the truck since doing the hot torque. After that I picked up a rough idle due to a misfire which turned out to be #7 becoming unplugged. Went BACK under the VCs to fix that and check all other plugs/connections.
I don't know why they were so loose in so short a time (all new stuff in the holes? ).
Even a few miles after doing all that I have a noticeable tick at idle again. So far it doesn't sound too bad so I'm chalking it up to the engine's personality with the new injectors.
Again, glad to hear you're up and around!
When I was doing glow plugs and UVCWH and some other maintenance on my 02 cclb I dreaded doing the right side. I was also doing brakes and was procrastinating doing the right valve cover,while doing the brakes I was looking at the inner fender and decided to take it out and found out how easy it was to get the valve cover bolts off from the wheel well.
i know some of you said to use certain tools to make it easier and I have access to any tool I need (I’m a snap on tool dealer) and have done it in the pass from the top, but give it a try from the wheel well and see how much easier it is.
Going in from the wheel well is a little easier for the lower bolts but getting the wheel liner in and out (plus the screws) isn't worth it IMO for the amount of bolts you can reach. I just use a 1/4" ratchet with a shallow 12-pt socket for those guys and can reach from the top with little issue.
My problem is always getting the VC out and back in.
on
So yours is all up and doing well now? Great news!
Thanks for the kindness.
on
Yep
Removing the serpentine belt and then pulling the 4 bolts holding the AC pump in place allows it to move about 4" without removing A/C lines, which is just enough after removing the CAC tube and other stuff...
Up, yes. Doing well, no. The injectors are doing well (thank goodness since I had problems with P.I.S. and my warranty is up) but I'm battling an intermittent oil leak and the fact that I'm weeping coolant out of several places. It looks like a cup might not be fully seated or that the sealant failed but there is nothing but coolant in the overflow bottle. Not looking forward to the re-work if that's the case and even less looking forward to telling my wife.
You are not alone in your frustrations!
Unfornately my lower alternator bracket goes "over" (on top of) the A/C bracket making it incredibly time consuming to loosen the A/C bracket so I work with the A/C in place.
on
Leaning over the engine on the topside creeper, there are lots of sounds. I am missing a number of top and bottom frequencies that let most people pick out sounds amidst other loud noises. Unfortunately, it may be those sounds that overwhelm what I do have and I can't pick out what I need to. Or I could just be getting OLD! LOL.
Thanks for the welcome back
BTW, rain tonight. Pittsburgh is soon going to convert the stadium into an Ark....
