Tow Status screen everytime I start the truck
I towed my RV about 800 miles, now every time I start the truck, the default screen is now the "Tow Status" screen, even with no trailer attached.
Before towing for the first time, it always started up where I left it. Not sure what changed, I have not changed anything nor can I find a setting to set the default screen on the main display.
How do I get it to go back to the last screen that I used, when it starts?
Thanks,
Thanks,
If the truck is running when you disconnect The trailer it will recognize that it is no longer there. If you shut the truck off and then disconnect the trailer the truck thinks it is still connected when you start the truck next time, so you have to go in and manually disconnect it in the screen. It took me a couple times of towing to realize what was going on with that.
Jeebusillin
2017+ Super Duty
12-27-2019 04:25 PM
