1984 F150 300: Codes 63 10 11
Found a code reader at a local autozone. Got:
63: Throttle Position Sensor (TPS)
10: (pause)
22: MAP sensor
I need to figure out where these sensors are and how to test them. But, generally, any tips for this code combination? Plan of attack? The truck starts, runs, and just passed emissions, but is unbelievably slow- 0-60 is 31 seconds!
10: (pause)
22: MAP sensor
In this link Electronic Engine Control - ???Gary's Garagemahal page 56 and 57 are your electronic engine control. Look on page 57, you can see the manifold absolute pressure sensor and the throttle position sensor. The long rectangle thing below them is the computer.
Scroll down in this link, the diagrams will have a list of components and their locations. This is on page 63 in the link. Look in the list, it tells you the location of the MAP and the throttle position sensors, and it also gives you another page all the way to the right that has a picture of it. You can click on this link to find all the pages. 1986 EVTM - ???Gary's Garagemahal
The MAP sensor on my son's 1984 with 4.9L went out and the symptom was there was pinging under moderate load. Once replaced, it ran normally. The TPS is located on the inner fender near the battery [passenger side]. The Throttle Position Sensor is located on the throttle shaft nearest the radiator. For these items, I recommend Motorcraft... they can normally be found as NOS on eBay.
The TPS on my son's 1984 with 4.9L went out and the symptom was there was pinging under moderate load. Once replaced, it ran normally. The TPS is located on the inner fender near the battery [passenger side]. The Throttle Position Sensor is located on the throttle shaft nearest the radiator. For these items, I recommend Motorcraft... they can normally be found as NOS on eBay.
monstermadness
26
06-24-2011 10:05 PM
Flatlanded87
08-25-2006 07:03 PM
tfrain
04-08-2004 08:10 AM
