Diesel vs Gas Cab Questions
Hey guys and gals,
I have an 89 f150 I am building, and it has cab rust issues. I was looking for replacement cabs and came across a 90ish f super duty. Now I know most of the cab will be the same, what im really curious about is if the cab mounts may be different on the larger frame, as well are the clutch brake and gas pedal setups or area on the firewall different?
My f150 will be 4x4 m5od, so I realize I will be cutting out the floor a little for the transfer case lever. Im using all the wiring and interior from my f150 cab and I know diesel wiring and column would need to be changed. Just seems to be a few details I can't seem to find. Anyone with knowledge on differences please chime in!
Received 3,110 Likes
on
Thanks for the reply. Regarding pedal assembly, do you have any idea what is all different? Im wondering if a guy can piece together an adapter to make the diesel hydraulic clutch work with the m5od. May be easier just to swap that as well.
Regarding the wiring, if I remember to post back about it I will for sure, keep in touch about it with me, IF I end up going through with the truck.
on
Are these differences the same for 92-96 cabs? I'm looking for something to either replace the busted sheet metal on my truck, or put my drivetrain in. I've found another '95 F250 with a 7.3L with a thrown rod for $800. I might consider getting it depending on the difficulty of the swap; provided the body is straight.
Again, no difference gas/diesel cab 92-97 just reuse all your guts
tjc transport
Electrical Systems/Wiring
08-26-2008 05:00 PM
badsnake
11-03-2004 09:09 AM
