Any Torqshift techs on here!!??
Old 01-21-2018, 03:38 PM
WildWop's Avatar
WildWop
WildWop is offline
so I bought my truck used with 144xxx, now I have almost 200k on the clock. (05 F250 ccsb 4x4) it HAD 35s and now 33s, I have no knowledge of a tranny service ever being done, would it be wise to change the filters out and drain and fill fluid?? I know nothing about this transmission other than it’s electronic. In my chevys I’ve always been told that it’s a no no beings it drains the friction material out that’s in the fluid. I’m getting ready to go from Cali to Texas and back and I would like to do as much PM as I can.
Thank you all all in advance
P.S. there is no issues other than was seems like delayed shifts, no slipping. More or less feels like a excessive defueling before a shift, only in stock being that I run a SCT tuner.
And yes I know these trucks shift that way normally but it seems like a bit more.
Old 01-21-2018, 03:51 PM
69cj's Avatar
69cj
69cj is offline
I personally would drain the pan and replace the external filter. The internal filter needs changing at rebuild time only. Draining the pan wil take 8 qts. And the ext. filter change wil add another 8 oz. If the fluid is badly discolored I’d drive it 50 miles and then do another change. JMHO.
Old 01-21-2018, 03:55 PM
WildWop's Avatar
WildWop
WildWop is offline
It was low at one point, maybe like 55k ago before I threw some stage 2 in a bottle (Lucas) and more fluid in it. Been fine since. But it’s not dark really. Doesn’t smell burnt.
Old 01-21-2018, 04:00 PM
69cj's Avatar
69cj
69cj is offline
I would use only Mercon LV or SP. Torqueshift is a robust tranny but picky about fluids. I would also use nothing but OEM or Racor filters for the engine oil and fuel.
Old 01-21-2018, 04:29 PM
navistarnut's Avatar
navistarnut
navistarnut is offline
Enough said
Old 01-21-2018, 04:55 PM
OneCylinder's Avatar
OneCylinder
OneCylinder is offline
Hey WildWop, I really doubt that your 5r110 is working due to friction material suspended in the fluid. If it is, it's only a matter of time before it fails whether you change the fluid or not. Mine has 323+K on it, I have the fluid and filter changed at 70 or 80K depending when I feel like dropping it off. In your situation, I would service the transmision. Like you stated you don't have a service record and from what I've read these tranys require the recomended fluid.
Old 01-21-2018, 05:32 PM
wedge542's Avatar
wedge542
wedge542 is offline
might be a good time for the bigger pan and real filter inside upgrade. Several writeups on it here.
Old 01-21-2018, 06:14 PM
WildWop's Avatar
WildWop
WildWop is offline
whats the difference between the two fluids??
Old 01-21-2018, 06:15 PM
WildWop's Avatar
WildWop
WildWop is offline
what’s the different in LV or SP
Old 01-21-2018, 06:22 PM
69cj's Avatar
69cj
69cj is offline
The LV superseded the SP but both are compatible with each other. Get which ever is more available at the best price.
Old 01-21-2018, 06:24 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
Here is an excellent way to change all of the transmission fluid. https://www.ford-trucks.com/forums/1...-exchange.html
It's not true that friction material in the fluid keeps the trans running. That's what the filters are for, to remove this friction material. If it stays in the fluid it will cause the solenoids to fail. This myth has been perpetuated by people that don't understand how automatic transmissions work. It is NOT true.
MERCON LV and MERCON SP are very similar. I don't know the specific differences. Either one will work fine in the 5r110W TorqShift transmission.
Old 01-21-2018, 06:35 PM
WildWop's Avatar
WildWop
WildWop is offline
Thank you very much, thank all of you. You all were a big help, I’ll be changing my fluid here sometime this week!
Old 01-21-2018, 06:36 PM
WildWop's Avatar
WildWop
WildWop is offline
Question... the dipstick! What denotes how much is needed???
Old 01-21-2018, 07:00 PM
diesel_dan's Avatar
diesel_dan
diesel_dan is online now
1st, if you plan to keep the truck, listen to what Mark Rolltide said: update to the latest trans pan and filter - maybe a bit over a hundred bucks but you get full filtration. Here:
https://www.ford-trucks.com/forums/1...ns-filter.html
2nd, the guy that was on the design team that created your transmission is the other Mark (Kovalsky) that responded to your thread, I'd pretty much listen to anything he says...
If you do the pan and filter change to '08+, it is 9 Qts in a new pan with a new '08+ filter in the pan. Changing the front filter is optional once this new pan and filter is in place, other than a filter element needs to be in there...
Pretty easy on the dipstick, follow the cold or hot instructions in any Ford manual that has a Torqshift....
Scott
Old 01-21-2018, 07:05 PM
WildWop's Avatar
WildWop
WildWop is offline
Scott
I’ll have to get on that then. I was not aware that there was an updated pan!
Quick Reply: Any Torqshift techs on here!!??
