Adding LED reading/map lights
to all,
I want to sacrifice my working dome light wire to pull a new one plus two others for map/reading lights for the passenger and driver. My question is: "if i sacrifice my existing dome light wire, will it pull three wires through easily?" Is this problematic? Has anyone tried this? Does it work well?
I replaced mine with an 80's Ford unit. Its chrome with two little round lenses for map lights and a plastic cover for the courtesy light. These are easy to find on ebay or in wrecking yards. Since the map lights work from switches on the housing, it still only needs only one wire. The more difficult part was figuring how to mount it. Usually taking the more difficult approach, I removed the sheet metal mounting surface from the donor vehicle (bronco) and attached it to the 66. This way I had the mounting holes, mounting angle, recesses for the special wire connectors and ground (coming from a mounting screw) all in one. I'll try to get photos, unless you already have a unit in mind. More direct to your question...I wouldn't ever "pull" wires through. The single wire is certainly strong enough, but there are too many sharp edges on the sheet metal to compromise your insulation. You would hate to have a short show up now or later and risk fire. Just remove the headliner so you can see what your doing and route wires so they don't get pinched.
...that's the one, ND!
6t6...sorry for my mis-statement. You're absolutely right on the two wire setup. After recollecting, I realized that my wiring (in process) is such that the map lights are hot all the time and the courtesy light will be wired through door jamb switches which I added. Thanks for the correction!
pulling a new dome wire
to all,
i did pull the dome cover so i can see the wire all the way to the top of the door. there is still quite a pull to get new wires all the down to the circuit panel under the dash. if i pull the dome cover and try to pull three new wires down to the fuse box is this feasible? Anyone tried this?
Chris
Chris
The way I see it you only need 1 wire with power all the time as the wire there works off the doors right?
I would use the wire there to pull a string down, add the power wire to the string and the wire you used to pull the string and pull it all back up.
I don't see the need for a ground wire as you can do it add the ground at the light.
Dave - - - -
Dave - - - -
