1977 f100 needs help
If she was runnin' before you changed the filter then it was something you did...or didn't do during/after the change.
Fer instance: are the clamps secure around the filter and not letting the fuel pump suck air?
Is the flow of fuel on the filter pointing in the right direction? Some are propitiatory in that respect.
Any other changes you did - inadvertently or not - that you can remember?
77 ford f100 Fuel delivery issue??
77 ford f100
Ok so I have changed plugs, wires, fuel pump, fuel filter on carb. It starts, runs great but after warm up stalls and loses power. I am going to clean tank, lines and try to get carb adjusted. Anyone have any ideas on anything else it might be?? Thanks
RTennant71
16
06-13-2011 10:06 AM
