Exhaust brake
on
Exhaust brake
To those of you that have the 6.7, which mode do you use the exhaust brake while towing, there is regular exhaust brake mode, and automatic mode. It's a little confusing to me as it's the first time having an exhaust brake, and I haven't used the truck enough yet. I read the manual but it doesn't take the place of experienced users.
Received 6,719 Likes
on
I use my exhaust brake when I'm towing or if I'm going down a long pass unloaded.
I generally keep to the Automatic mode, but there are some mountain passes that I go to manual on. As near as I can tell it works like this:
Automatic: just what it says. You don't have to do anything. Top a pass at 55 MPH and it will keep you at ~55 MPH using the exhaust brake as well as lower gears in the transmission.
Manual: You have to gear down. Use the M mode on the gear selector and then the +/- button on the gear selector handle. As near as I can tell, the exhaust brake doesn't do anything in Manual mode if you aren't manually shifting.
The above is based on my experience, not from reading the manual.
on
I use both modes when towing my 16K fiver. In tow/haul mode I use manual mode when on interstate or in town traffic. When letting off the go pedal it will slow you some, but every time you touch the brake pedal it will cause a downshift and up the pressure on the exhaust brake. When in the mountains I will use the auto mode. As I top a mountain, I let off the go pedal and sometimes will touch the brake pedal. After touching the pedal, your speed will stay there.
Regular driving in hilly country, I usually turn on manual....
It is fantastic when combined with cruise control in mountain towing.
On the Interstate with our without our 5th wheel trailer, exhaust brake off.
On 2 or 4 lane open roads with no major hills, exhaust brake off.
On 2 or 4 lane roads around towns without trailer, exhaust brake off.
On 2 or 4 lane roads around towns with trailer, manual exhaust brake on.
Mountains around here on the downhill side, with or without the trailer, manual exhaust brake on, transmission in manual mode (3rd gear with trailer, 4th without trailer). We have fairly long 7% grades, with sharp curves (some marked as 20 mpg safe speed) along with some straight stretches. Selecting the gear manually allows the truck to roll a bit on the straight stretches, but not downshift severely when I brake for the curves. 3rd gear with a trailer seems to be a good compromise, with slight braking needed to slow down for the curves.
I live in the mountains of western North Carolina and I am always going over some mountain. What I do is turn on tow haul when going down hill, tap the breaks to down shift to what ever gear I want take my foot of the go pedal and let it cost. When I want or need to slow down I hit the EB once to slow down when I want to go hit the EB button twice to turn it off, repeate as needed. Once your down turn off tow haul and keep on trucking. I do the same when towing. In auto mode the truck will remember what speed you where going when you took your foot off the gas and keep you at that speed, it will downshift as needed automatically or upshift if needed. I don't use auto very much because I have control issues. Enjoy your new truck.
