Exhaust brake - Ford Truck Enthusiasts Forums
Exhaust brake
Old 12-28-2017, 02:14 PM
brickman
brickman is offline
brickman is gaining momentum as a positive member of FTE.brickman is gaining momentum as a positive member of FTE.
Exhaust brake
To those of you that have the 6.7, which mode do you use the exhaust brake while towing, there is regular exhaust brake mode, and automatic mode. It's a little confusing to me as it's the first time having an exhaust brake, and I haven't used the truck enough yet. I read the manual but it doesn't take the place of experienced users.
Old 12-28-2017, 09:51 PM
Larrymac52
Larrymac52 is online now
Larrymac52 is starting off with a positive reputation.
to piggy back on Brickmanís question, besides using the EB while towing, do you use it on unloaded rides and if so what mode?
Old 12-28-2017, 10:13 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud ofHRTKD has much to be proud of
I use my exhaust brake when I'm towing or if I'm going down a long pass unloaded.
I generally keep to the Automatic mode, but there are some mountain passes that I go to manual on. As near as I can tell it works like this:
Automatic: just what it says. You don't have to do anything. Top a pass at 55 MPH and it will keep you at ~55 MPH using the exhaust brake as well as lower gears in the transmission.
Manual: You have to gear down. Use the M mode on the gear selector and then the +/- button on the gear selector handle. As near as I can tell, the exhaust brake doesn't do anything in Manual mode if you aren't manually shifting.
The above is based on my experience, not from reading the manual.
Old 12-29-2017, 07:09 AM
69cj's Avatar
69cj
69cj is online now
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
I set both the CC and EB. Keeps the truck within a mile or two climbing or descending.
Old 12-29-2017, 07:35 AM
brickman
brickman is offline
Do you use the EB in auto or manual?
Old 12-29-2017, 07:39 AM
brickman
brickman is offline
Thanks that helps. I always thought the EB only worked in conjunction with the brake pedal.
Old 12-29-2017, 05:55 PM
slapshot12
slapshot12 is offline
slapshot12 is starting off with a positive reputation.
I use it in auto mode only when towing my trailer, otherwise, it stays off.
Old 12-30-2017, 05:24 PM
69cj's Avatar
69cj
69cj is online now
Auto, donít need manual in that scenario even when towing.
Old 12-30-2017, 06:39 PM
travlingman
travlingman is offline
travlingman is gaining momentum as a positive member of FTE.travlingman is gaining momentum as a positive member of FTE.
I use both modes when towing my 16K fiver. In tow/haul mode I use manual mode when on interstate or in town traffic. When letting off the go pedal it will slow you some, but every time you touch the brake pedal it will cause a downshift and up the pressure on the exhaust brake. When in the mountains I will use the auto mode. As I top a mountain, I let off the go pedal and sometimes will touch the brake pedal. After touching the pedal, your speed will stay there.
Old 12-31-2017, 09:05 AM
Krazyhorse
Krazyhorse is offline
Krazyhorse is gaining momentum as a positive member of FTE.
My experience as well. Towing on Colorado mtn. passes.....auto.
Regular driving in hilly country, I usually turn on manual....
It is fantastic when combined with cruise control in mountain towing.
Old 12-31-2017, 08:46 PM
captcolour
captcolour is offline
captcolour is gaining momentum as a positive member of FTE.
+1 on manual mode. You don't have to downshift first, just touch the brake pedal. I have been using just manual mode both around town and when towing. Will have to try automatic mode when towing.
Old 01-02-2018, 01:16 PM
mtnguy
mtnguy is offline
mtnguy is starting off with a positive reputation.
On the Interstate with our without our 5th wheel trailer, exhaust brake off.
On 2 or 4 lane open roads with no major hills, exhaust brake off.
On 2 or 4 lane roads around towns without trailer, exhaust brake off.
On 2 or 4 lane roads around towns with trailer, manual exhaust brake on.
Mountains around here on the downhill side, with or without the trailer, manual exhaust brake on, transmission in manual mode (3rd gear with trailer, 4th without trailer). We have fairly long 7% grades, with sharp curves (some marked as 20 mpg safe speed) along with some straight stretches. Selecting the gear manually allows the truck to roll a bit on the straight stretches, but not downshift severely when I brake for the curves. 3rd gear with a trailer seems to be a good compromise, with slight braking needed to slow down for the curves.
Old 01-02-2018, 06:39 PM
Canvas Man's Avatar
Canvas Man
Canvas Man is offline
Canvas Man is starting off with a positive reputation.
I live in the mountains of western North Carolina and I am always going over some mountain. What I do is turn on tow haul when going down hill, tap the breaks to down shift to what ever gear I want take my foot of the go pedal and let it cost. When I want or need to slow down I hit the EB once to slow down when I want to go hit the EB button twice to turn it off, repeate as needed. Once your down turn off tow haul and keep on trucking. I do the same when towing. In auto mode the truck will remember what speed you where going when you took your foot off the gas and keep you at that speed, it will downshift as needed automatically or upshift if needed. I don't use auto very much because I have control issues. Enjoy your new truck.
Old 05-25-2018, 06:02 AM
kevin211
kevin211 is offline
kevin211 is starting off with a positive reputation.
Does anyone have the after market EB? i'm looking to install on on my 2013 f-250 for towing when the time comes
Old 05-25-2018, 08:32 AM
BPofMD's Avatar
BPofMD
BPofMD is online now
FTE MD Chapter Ldr
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Don't know why you'd think you'd need one kevin. The TOW/HAUL mode built into these trucks is plenty ! Pulled my 30' 5er all over the US and it's never met a mountain it couldn't handle.
Quick Reply: Exhaust brake
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
